Lens Hood
Discussion in 'Photography Beginners' Forum' started by JayPearson, Nov 16, 2008.
  1. JayPearson
    JayPearson TPF Noob!
    Sep 30, 2008
    53
    MS, Coast
    I'm in the process of buying a few new lenses. One of them will be the 50mm f/1.8 and the other will most likely be a tele. I've seen hoods for both lenses that i'm looking at. I was just wondering if you need a hood for certain lenses.
  2. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    I have a hood for my 28-135, but when I bought the 50 1.8 I asked if people thought I should get a hood for that, and they said naah, you mostly just need hoods for longer focal lengths. So no I don't think you need one, IMO.
  3. JayPearson
    Sep 30, 2008
    53
    MS, Coast
    See thats exactly what i thought. I suppose i will just buy the hood for the tele then.
  4. iflynething
    iflynething TPF Noob!
    Oct 26, 2006
    1,346
    South Carolina USA
    It should come with it. Hood help reduce lens flare when shooting close to the sun....as in direction wise
    ~Michael~
  5. tirediron
    Jul 8, 2005
    41,108
    12,494
    Victoria, BC
    If you have a lens, get a hood for it; you don't want it to catch a cold right? Seriously, aside from the optical benefits, they offer good protection for the front element. I have hoods on all of my lenses.
  6. JayPearson
    Sep 30, 2008
    53
    MS, Coast
    So it wouldn't hurt if the 5omm had a hood?
  7. iflynething
    Oct 26, 2006
    1,346
    South Carolina USA
    Not really worth it on a 50mm. Optical benefits........from a hood?
    ~Michael~
  8. stsinner
    stsinner TPF Noob!
    Oct 27, 2008
    1,860
    8
    Massachusetts
    Every expert I've read says that they always use hoods, because they can't hurt, but that one shot where light is coming in a window behind their subject and the contrast is off, they'll wish they had one...
  9. *Knowledge*
    *Knowledge* TPF Noob!
    Dec 6, 2007
    68
    Californication
    I have hoods on all my lenses; truthfully, I don't know any reason why anyone wouldn't utilize hoods.
  10. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    Yes, If the front element gets scratched, then the optics are not as good as they could be. A hood provides protection for the lens including the front element. Every lens should have a lens hood and the hood should be used at all times unless there is a particular shot that makes the use of the hood impractical/impossible.
  11. davebmck
    davebmck TPF Noob!
    Mar 10, 2008
    678
    Waxhaw, NC
    I have clear UV filters on all my lenses for protection. While the hood can provide additional protection for the lens, the main purpose is to prevent reflected light from creating problems like lens glare. This is primarily a problem outdoors, but occasionally can happen indoors. If you plan to use your 50mm indoors, you probably don't need a hood for it.
  12. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    Without reading all the previous replies......... get and use the proper hood for your lens. Period.
    I don't use "protective" filters, but always employ the hood.
    [EDIT] Okay I just kinda, sorta read the previous replies. The consensus is to use the hood. I have 9 lenses and only two came without a hood. One I could care less about and the other I can and do swap hoods from another lens. Don't be a numbnuts.... get the hood.
