Lens Hoods
Discussion in 'Photography Beginners' Forum' started by eric-holmes, Oct 5, 2009.
  1. eric-holmes
    eric-holmes No longer a newbie, moving up!
    Aug 8, 2009
    1,858
    49
    Arkansas
    How interchangeable are lens hoods? I would like a different one for my camera but I don't know if I can trade them out. Right now I have a solid one and I would prefer one with the edges cut out.
  2. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    Lens specific.
  3. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    Yep - lens specific. Even if a different one might fit on another lens, you should use the one that's for your lens. Also, if the end of the lens turns when you focus, a petal hood is pointless. Why are you wanting a petal hood instead of solid?
  4. syphlix
    syphlix TPF Noob!
    Jul 23, 2009
    687
    NYC
    petal hood is prettier!
  5. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    don't confuse function with pretty:lol:
  6. Randall Ellis
    Randall Ellis TPF Noob!
    Sep 9, 2009
    175
    Central Florida
    Some lenses, primarily wider angle lenses, require hoods that are cut differently to prevent them from vignetting the edges of the frame. If the lens you are using is not overly wide for the format you are using you should be able to use any generic rubber hood with it. These are inexpensive, so you might consider trying on to see if the corners of your images are darkened or not. If not you're good to go...
    - Randy
  7. Buckster
    Buckster Been spending a lot of time on here!
    Sep 14, 2009
    6,399
    2,334
    Way up North in Michigan
    Strictly as a functionality issue, this is an interesting resource for the DIY types (I'm into the whole DIY thing):
    Free printable cardboard lens hoods
    With the templates provided as a starting point, and a bit of work with some stiff plastic or even sheet metal, and some black paint or gaffer's tape or something like that, someone with a bit of time and skill can make any lens hood they might need for pennies.
  8. easilyamused
    easilyamused TPF Noob!
    Sep 24, 2009
    6
    Massachusetts
    Buckster,
    That site is really clever. What materials have you tried when you've made yours? I'm tempted to try to make one out of plastic, but I'm not sure what kind of plastic I'd need or where to get it.
  9. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    I bet chopping up the cover of one of those flimsy plastic binders would work well.
  10. Buckster
    Sep 14, 2009
    6,399
    2,334
    I haven't made one from plastic yet, but I'm thinking milk jug or 2 liter soda bottle would work pretty good, once covered or painted. I've made some out of cardboard covered in gaffer's tape that work fine.
  11. eric-holmes
    Aug 8, 2009
    1,858
    49
    Arkansas
  12. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,028
    15,012
    USA
    One thing about lens hoods: virtually ALL older lenses and their hoods have been designed for use on FF cameras. On DX d-slr bodies, the hoods for those lenses are not long enough, or small diameter enough; because the APS-C d-slrs crop off so much of a lens's angle of view, you actually need a longer and/or more-restrictive lens hood than if using a FF body with the same lens.
    Soft, bendable rubber lens hoods work pretty well. The cutout or "petal" lens hoods look pretty cool, but circular hoods work well. One of the advantages of softer, bendable rubber hoods is that they can be squished a bit to throw a shadow on the front of the lens when shooting in extremely tough conditions, with the lens aimed toward a bright sun.
    Camera stores (does anybody remember those?) often have bins full of older lens hoods for $3-$5 each. You can often find a decent hood with a bit of fitting and checking for vignetting at minimum aperture (f/16, f/22) and close focus, aimed at a bright light source, like the sky. If the corners of the frme are darkened, the hood is too long or too narrow in diameter. On APS-C digital, the hood specified for an 85-90mm lens will work on a 50mm lens,and so on.
