Lens Mount Question (Canon DSLR)
Discussion in 'Photography Beginners' Forum' started by iskoos, Dec 15, 2009.
  1. iskoos
    iskoos TPF Noob!
    Nov 19, 2009
    187
    Orlando, FL
    Hi,
    I plan on buying a Canon DSLR. I found out that 5D and Rebel series DSLR's use same lenses. In other words, they do have the same lens mount (what Canon calls "EF").
    I definitely liked this because this way, I will be able to keep my lenses when I upgrade the body in the future.
    But at the same time, I didn't understand it.:???:
    Rebel series use APS-C size sensor and 5D uses full frame sensor.
    How would they use same lenses? Doesn't the lens diameter change with the image size sensor?
    I am hoping somebody will explain this to me?
  2. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    5D: EF mount lens only
    Rebel: EF and EF-S mount lens
    If you buy only EF lens, you can use the lens on any Canon EOS cameras including film based EOS cameras.
    Quoted from Wikipidea:
    "The "S" in EF-S stands for "short back focus", which means that the rear element of the lens is closer to the image sensor than on regular 35 mm SLR cameras."
  3. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
    Canon actually has 2 variants on the lens mount ... the EF and the EF-S. The EF-S lenses are only useable on the crop-sensor cameras, whereas the EF mount is useable on any EOS camera. If you are thinking of upgrading your camera to a Full Frame body, buy only EF mount or be prepared to sell your EF-S lenses.
  4. iskoos
    iskoos TPF Noob!
    Nov 19, 2009
    187
    Orlando, FL
    I see... It makes more sense right now.
    The lense rebel series cameras come with is 18-55mm EF-S lense. This lense will NOT work on 5D because 5D only uses EF lenses...
    Alright so far... But can someone also explain if EF lenses have larger diameter than EF-S lenses?
    I am hoping you understand where I am coming from. I am trying to find out what determines the lens diameter...
  5. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    why??
  6. iskoos
    iskoos TPF Noob!
    Nov 19, 2009
    187
    Orlando, FL
    So when somebody askes me the same thing one day, I do not have to ask the question of "why??" and be able to explain them instead...
    Do not get mad at me but I would like to learn things rather than memorizing them... When you truly learn what it is, you will never forget. If you memorize, you will forget it one day...
    It is just how me works...:)
  7. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    What, specifically, are you talking about when you say 'lens diameter'?
    The front of the lens? The diameter of the body? The mount?
    The mount is the same, but the actual size of the lens is determined by the design of the lens; the maximum aperture, the features (IS etc) and so on.
    One thing that does change between EF and EF-S lenses, is the size of of the image circle at the film plane (sensor). Since EF-S lenses are made for cameras with a smaller sensor, their image circle doesn't need to as big as the one that EF lenses need to create.
    This is why, if you did rig an EF-S lens to fit a fill frame camera, you would have a vignette on the corners.
  8. t00sl0w
    t00sl0w TPF Noob!
    Dec 12, 2009
    79
    jax FL
    not to thread jack....but this may be relevant....
    is there a adapter for a 4/3 35mm to the EF mount?
  9. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
  10. JButler
    JButler TPF Noob!
    Dec 15, 2009
    16
    The lens diameter doesn't matter. What you care about is the size of the image that's projected on the camera's sensor. EF-S lenses project a small image in the sensor. Large enough to fill up an APS-C, but too small for a full frame sensor. If you shot an EF-S lens on a 5D your images would come out as little circles.
  11. iskoos
    iskoos TPF Noob!
    Nov 19, 2009
    187
    Orlando, FL
    Well, the lens diameter does matter. You confirm this in your paragraph above. If the lens diameter would not matter then, they would make the full frame cameras work with tiny lenses that we see on P&S cameras. Do you think this would be possible?
    I am pretty sure we talk about the same thing but perhaps I couldn't explain myself well.
    Big Mike, your last paragraph is I guess what I was asking about: image circle. EF-S lenses create smaller image circle for smaller image sensors and EF lenses create larger ones deu to the full frame sensor size.
    When I was asking about lens diameter, I was asking in general but it looks like there is not one specific lens diameter we can talk about.
  12. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    There are probably hundreds of parts to a lens that have a diameter...you just needed to be more specific. ;)
