Lens or Body
Discussion in 'Beyond the Basics' started by julie32, Dec 3, 2007.
  1. julie32
    julie32 TPF Noob!
    Jun 25, 2007
    354
    New York City
    I have a 3 yr old Canon 20D with a 24-70mm 2.8 SIGMA lens. I have the opportunity to purchase a 5D body OR a CANON 24-70mm 2.8 lens.
    What should I get and why?
    Thanks so much.
    Jules
  2. JDS
    JDS TPF Noob!
    Aug 3, 2006
    592
    Oakdale, TN
    Do you shoot professionally? Like weddings for instance.. It would be good to have a backup body...use the 5D as your main and your 20D as the backup.
  3. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    The Sigma lens is not a bad lens, however it's weaknesses are rather obvious when compared to the Canon L lens.
    I would be tempted to get the lens.
    But then again the 20 D is quite an old body by now, and I have used the 5D with the Sigma 24-70mm f/2.8 lens, not a bad combination. With a bit of RAW-processing to get rid of the chromatic abberation of that lens, it is quite a good combination. You will enjoy the true 24mm wide angle at the 5D full frame sensor.
  4. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    Neither the 20D nor the Sigma lens are "bad".. in fact they are both very good even by today's standards.
    Do you find anything limiting about the camera?
    Do you find anything limiting about the lens?
    Me personally.... I'd stick with the combo and spend the money on some nice primes. You have a fast lens when you need the convenience of a zoom. A set of primes will give you "uncompromised" image quality and even faster aperture.
  5. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    get the L. The 20D is perfectly capable...
    I have the 4.0 version, and it's awesome...but as soon as I can I want to invest in Canon's flagship zoom...the 70-200 2.8L. I'm positive you won't be disappointed. It's super sharp, great contrast...everything.
    The focal length is also very usable on a crop camera.
  6. julie32
    julie32 TPF Noob!
    Jun 25, 2007
    354
    New York City
    I don't shoot weddings, but I do shoot an advanced amateurl level, if that's possible. I photography children as my second "job." I do get some abberation with the sigma and it just doesn't seem very sharp unless I'm doing something wrong, which is entirely possible.
    I have no real problems with the 20D, I've just heard how beneficial the full frame sensor is. I look at a ton of my competitors in the area and I check the file info from a photo they took (off a blog) and of course..it's a 5D.
    Also, novice question: what's the benefit of using a 50mm lens instead of a zoom?
    Thanks for taking the time to respond.
    julie
  7. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    I'd so pick the lens over a better body.
  8. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    An OK body with a great lens will get you better results than a great body with an OK lens.
    However best results come when you put a great lens on a great body.
  9. JDS
    JDS TPF Noob!
    Aug 3, 2006
    592
    Oakdale, TN
    What makes the 50mm 'better' than most zooms is that it is a prime lens. That sounds sort of redundant, but let me get there.. :) The fact that it is a prime lens (no zoom) makes it easier to manufacture well - the only moving part is the focus, no worrying about multiple pieces lining up just right without getting distortion, etc. They put the glass in the right spot, and leave it.
    But when you start talking about Canon L glass, that's a whole other ballgame. :)
  10. usayit
    Nov 15, 2003
    9,523
    346
    L glass is not a whole other ballgame.... L zooms are still inferior to L primes. Hell.. some of canon's regular consumer primes will give an L zoom a run for its money.
    It is all about simplicity.. designing a group of glass lenses to zoom requires a bit of sacrifice. Some will even claim that the 70-200m f2.8 IS is slightly inferior in image quality to the 70-200 f2.8 non-IS due to the fact that the non-IS version is more simple in design ( more elements /groups).
  11. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    hm, looks like all said :)
  12. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,699
    68
    Missouri
    Lens.
