lens problem
Discussion in 'Photography Equipment & Products' started by momoe, Oct 17, 2009.
  1. momoe
    momoe TPF Noob!
    Sep 21, 2009
    9
    I have a tamron 100-300mm zoom lens for my canon. the lens took a fall and now it sounds like a screw or something small it rolling around in there. it will catch and not extend at times like something is trapped. if i point it up and close the extention all the way it will then extend out to 300. I think it would cost more to fix it than its worth. it also will not fine focus after about 200mm. if I take the plate off the back, will that allow access to the center channel where I am hearing the rattle?
  2. tirediron
    Jul 8, 2005
    40,894
    12,417
    Victoria, BC
    Possibly, but not likely. Lens construction is very complicated and very convoluted. You're not going to take off the mounting plate and find a big open tube or anything like that. You certainly can take lenses apart, and in the days of all mechanical lenses, I took apart and repaired a number of my own, but with all the electronics, ribbon cables etc in a modern lens, you're really walking in to a mine field. If you don't feel it's worth the cost of repair, and don't mind taking a chance that the lens will become nothing more than a paperweight, go for it, but if you still want to be able to use the portion that works, I would leave well enough alone.
