Lens Protection
Discussion in 'Photography Equipment & Products' started by kkamin, Aug 25, 2009.
  1. kkamin
    kkamin TPF Noob!
    Aug 25, 2009
    514
    17
    Minneapolis
    What do you call the lens protectors? They screw on like filters but are obviously clear glass. Where can I buy quality but inexpensive ones for my Canon lenses?
  2. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    Usually IR filters, but you can get actual clear glass ones... I dunno what you would call those, however, since usually people just get IR filters.
    Just keep in mind it changes the properties of your lens a little bit, and can and will have an effect on the image.
    B&H and Adorama have a nice supply of these. Just get the diameter of the lens from inside the lens cap (usually something like 77mm) and order the right size to fit.
  3. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I think he means UV filters, not IR filters.
  4. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    No and no.....
    The filters the OP is looking for are window glass filters or optical flats.
  5. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    I think they are called 'lens caps'. :D
  6. KmH
    Apr 9, 2009
    40,742
    5,588
    Iowa
    Quailty but inexpensive is an oxymoron.
    Use a lens hood.
    Screw-in filters provide only limited protection and can actually cause damage to your expensive lens objective glass if the filter shatters from an impact.
    Case on point.
  7. MelissaMarieImagery
    MelissaMarieImagery TPF Noob!
    Aug 11, 2009
    232
    Bay Shore, NY
    ^That suuucks
    however, there are cases where something could jump up and hit the filter, and just put a ding in it, that would have been on the lens instead. So it's really situational. Like "if he were wearing his seatbelt he wouldn't have been ejected from the car" and "oh he strangled because he wore his seatbelt".. poor analogy but hopefully you get where I'm going with it lol.
  8. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
    I stopped using UV filters to protect my glass and now just try to keep a lens hood on. On the other hand, I had an ostrich peck my CP at close range and scratch it up -- might have messed up my front element if I hadn't had the filter on (also might have messed up my hand if his aim was better) ....
  9. manaheim
    Sep 2, 2005
    14,394
    3,262
    oops. yes, sorry. :)
  10. itznfb
    itznfb TPF Noob!
    May 21, 2008
    1,167
    Pittsburgh, PA
    i can't believe people rely on lens hoods to protect their lenses. there is no viable data to show that any filter reduces the quality of an image. and it only takes one little branch to cost hundreds or thousands of damage a $80 filter could have prevented. i could throw a $5 Quantaray filter on my 18-50mm f/2.8 and post a with and without and i guarantee no human could tell the difference; or any analysis software either for that matter. just put a UV or clear on there for protection and be done with it.
    canon makes a few protective filters
    http://www.bhphotovideo.com/c/search?ci=112&N=4294540717 4291570227
  11. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    The front element is the cheapest piece to replace on any lens. As for filter, they do reduce IQ, particularly if they're cheap. And they most certainly increase the risk of flare (that much is common sense if you understand why lens flare occurs).
  12. itznfb
    itznfb TPF Noob!
    May 21, 2008
    1,167
    Pittsburgh, PA
    i've never heard of any lens repair being cheap. and are you able to prove filters reduce IQ? because i've never seen proof of such a claim.
