Lens Question
Discussion in 'Photography Beginners' Forum' started by linpelk, Mar 8, 2009.
  1. linpelk
    linpelk TPF Noob!
    Jan 1, 2009
    406
    California
    I love my 50mm f/1.8, but I mostly shoot my kids with it and I feel like I have to back up a lot to get them in the frame. It's frustrating for me especially when I'm in a small room and I can't physically get any further away. I also have a 24-105 f/4L lens and I love it, but it doesn't do indoor shots as nicely (obviously...the f/4) and I love the bokeh I get with the 50mm. I was wondering if there is another lens that would allow me to be closer but would still have the large aperture? I am wondering if it distorts the subject.
    I've heard that a portrait lens is ideally closer to 100mm?? (Is that correct?) Why is that?
  2. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,155
    930
    Woodbridge, Ontario, Canada
    A portrait lens focal length was commonly 100mm to get upper body shots in the studio.
    Your 50mm on a DSLR will most likely be equivalent to 85mm (1.5x crop).
    To get a wider field of view you will want something wider like a 28 or 30mm lens. It is hard to get a lens with a very wide aperture (f/1.8) like your 50mm.
    I think Nikon makes a 35mm f/1.8 prime.
  3. dxqcanada
    Dec 4, 2008
    6,155
    930
    Canon has a 28mm f/1.8 and a 35mm f/2.0
  4. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    Get the nikon 35 G, or canons equivalent.
  5. TheOtherBob
    TheOtherBob TPF Noob!
    Mar 27, 2007
    289
    UWS, NY, NY
    I understand you're a Canon shooter -- if you want to stick with fast primes, I think there's a 35mm 2.0 for Canon, or a (kinda expensive) 35mm 1.4. Another is the 30mm 1.4 from Sigma. I haven't used any of these lenses, but they could be options for you.
  6. linpelk
    linpelk TPF Noob!
    Jan 1, 2009
    406
    California
    I just looked on B&H and found the Canon 28mm f/1.8 lens and it sounds like what I want (large aperture, closer range) but it says "wide angle" does that mean that it's meant to shoot landscapes and not necessarily people? Will it distort a person if the photo is taken in close range?
    By the way, thank you all for your replies!
  7. dinodan
    dinodan TPF Noob!
    Jan 21, 2007
    417
    Charleston, South Carolina, USA
    If you're shooting Canon digital, the 28mm will equate to roughly a 45mm full-frame (just slightly wider than so-called "normal", which is 50mm full-frame). This will give you a much wider field of view than your 50mm (which equates to roughly 80mm) and should work quite well. There should be no problem with distortion because, while this can occur with wide angle lenses at the extreme edges of the frame, those areas will be cropped out with a digital sensor.
    I shoot with a Nikon 28mm on my D80 and find it to be quite a useful general purpose lens. I think you'll be quite happy with the 28 f/1.8.
  8. TheOtherBob
    Mar 27, 2007
    289
    UWS, NY, NY
    One warning -- the 28mm 1.8 Canon has received some bad reviews. See Canon EF 28mm f/1.8 USM Lens Review
    Depending on what you intend to use it for, this may not be a great choice.
  9. blash
    blash TPF Noob!
    Nov 19, 2008
    599
    28mm will work out nicely on a cropped body - distortion won't be as flattering from a portraiture perspective, but it will let you do what you want to do apparently. Personally I'd stick with the 50 for portraiture but that's just me :)
  10. linpelk
    linpelk TPF Noob!
    Jan 1, 2009
    406
    California
    Thanks for the tip. I guess I need to read up a bit on reviews, etc. before buying anything. That's what is so great about the 50mm...for $80 you can't really regret the purchase. When spending hundreds, well, that's a different story.
    Thank you all for your replies.
  11. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    That ideaology is a little out dated (so to speak, as it does apply to modern full frame digitals), 85mm, 100mm and 135mm are common portrait lenses when shooting full frame, however on modern crop bodies this all becomes confusing and way too long. On a crop body for portrait work you are looking at prolly 35mm, 50mm and 85mm. this should get you into roughly the same range as the afore mentioned full frame equivalents.
  12. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    People get hung up on "crop factor" too much. I see people with the "Get a 100. . .on a crop body its almost 150MM!!!!" How would you (or the people you are helping) know the difference?
    To the op, just recognize that about 30 and under is where you start to get "wide". Anything above gets you in the "tight" category where you are having to shift and shimmy to toss in what you want to toss in.
    For you, if you are going to primarily use this lens indoor - get a 12-24 Tokina as well as a Speedlite. Low light problem solved.
