Lens question
Discussion in 'Beyond the Basics' started by Macro, Jan 6, 2004.
  1. Macro
    Macro TPF Noob!
    Dec 27, 2003
    9
    Oregon
    I was looking at macro lenses and came across a MP-E65mm f/2.8 1-5x Macro Photo. What is a mp lens and will it work with the 10D?
  2. doxx
    doxx TPF Noob!
    Aug 4, 2003
    499
    behind the viewfinder
    it's a manual focus lens - I personally find it tricky to focus manually with the 10Ds small viewfinder. Then you need to consider the magnification factor x 1.6 of the 10D.
    http://www.photo.net/photo/canon/mp-e-65/
    hope this helps
  3. FatVana
    FatVana TPF Noob!
    Jan 7, 2004
    18
    LA
    The 1.6 magnification factor is a very misleading thing. I found this on the net and it really cleared things up for me. I hope it's helpful.
    "First of all, the correct term is an FOV Crop. Focal Length Multiplier is a misnomer.
    A few things are in order first:
    - The FOV Crop on the 300D, like the EOS 10D, is 1.6. This is because the CMOS sensor is smaller than a 35mm frame.
    - The focal length of a lens is the distance from the rear glass element to the focal plane at infinity focus.
    - We're used to relating the 35mm focal-length to what we see in a picture as "zoom"
    Since the 300D/10D/other digicams have smaller sensors, they're only seeing a portion of the image that a 35mm full-frame sensor or film would see. This is where the FOV crop comes into play.
    That said, taking a picture with Canon's excellent 50mm f/1.8 lens is still a normal lens. Distortion of the image will be the same in full-frame as in the smaller sensor. However, you won't see as much of the image -- you'll see the same amount of the image as if you had an 80mm lens on there (50mm * FOV Crop). This is why a 50mm prime lens is still good for the 300D/10D sized sensors as a "normal" lens. "
    marius
    [/quote]
  4. mrsid99
    mrsid99 TPF Supporters Supporting Member
    Mar 8, 2003
    2,964
    5
    Florida
    Would it be possible to use the LCD display as a viewfinder?
  5. doxx
    doxx TPF Noob!
    Aug 4, 2003
    499
    no, since the 10D is an SLR it's impossible - mirror in the way
  6. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    Doxx
    I have a FD to EF converter, a problem I am have with the FD lens on 10D is the light meter reading and settings
  7. doxx
    doxx TPF Noob!
    Aug 4, 2003
    499
    Jeff, I can only offer my best guess here... since the 10D (and other EOS cameras too) controls the aperture electronically I doubt it stops down with the FD converter. So you'll need to stop the lens down manually and use the camera in manual mode to adjust the shutter speed :scratch: Don't take me for granted on this one...
