Lens question
Discussion in 'Digital Discussion & Q&A' started by ipon, Jun 2, 2006.
  1. ipon
    ipon TPF Noob!
    Jan 5, 2006
    69
    I know this might be a newb question, but is the D50 and D200 lens interchangeable? kinda don't want to spend to much on lens for the D50, cause maybe want to ugrade to the D200 later.
    thanks...
  2. thebeginning
    thebeginning TPF Noob!
    Jan 10, 2005
    3,795
    30
    Texas
    in most cases the lens is much bigger of a factor than the camera as far as image quality goes...not counting resolution (there is a noticeable jump from 6mp to 10mp). so you may want to consider that...most people start with a standard/cheapish cameras, build up a nice lens array, then buy a nicer body and use their old body as backup (usually pros do this). but to answer your question yes, they have the exact same mounts.
  3. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    Same lenses, no problem. If you're starting out - get the D50 as it's more than good enough for the time being and you'll have more cash for tripods, lenses, memory cards etc. Then you can buy the D3000 or whatever when it comes out!! ;)
    Rob
