Lens Reversing Ring/Lens coupling rings for macro
Discussion in 'Photography Beginners' Forum' started by Bobby Ironsights, Jan 17, 2007.
  1. Bobby Ironsights
    Bobby Ironsights TPF Noob!
    Dec 3, 2006
    328
    12
    Thunder Bay, ON, Canada
    Lens Reversing Ring / Lens coupling rings for Extreme macro
    I've seen these advertised with some rather nice demo shots.
    Do these work? or are they simply a marketing gimmick.
    Basic physics seems correct.
  2. jwkwd
    jwkwd TPF Noob!
    Oct 26, 2005
    630
    Western N.Y.
    Yes the basic phisics are correct, and they do work quite nicely.
  3. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    2,748
    184
    Lens reversing creates three problems. The first is working distance. Depending on the focal length and focal point it is possible to have negative working distances. A reversed lens focuses really, really closely.
    The second problem is speed. Remember it is the front element of the lens that determines the maximum aperture. With a reversed lens the smaller rear element determines it. It makes for a fairly dark viewfinder and fewer options for depth of field. To be fair, you get a lot of light loss with extension rings or bellows as well.
    The third is correction of lens aberrations. Lenses are corrected for light entering at the front of the lens, not the rear so your lens won't be as well corrected in the reverse direction.
    On the plus side it is possible to get reproduction ratios greater than 1:1.
  4. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    It's a cheap way to get into macro photography. I find the biggest problems are the close working distances and the very shallow DOF...but you can buy the ring for around $10 (or even just use tape).
    Here is a shot I took with a reverse macro ring.
    [​IMG]
  5. asr84
    asr84 TPF Noob!
    Jan 18, 2007
    46
    CH, Lausanne
    Awesome! Nice info guys, thanks. Those rings exist also for a Nikon D50 18-55mm?
    I gotta buy 1 right now. Price is very low compared to other accesories...
  6. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    They are just a simple piece of metal with two sets of threads. The idea being that you use the filter threads to attach one lens to the front of another. So you do have to have two lenses.
  7. asr84
    asr84 TPF Noob!
    Jan 18, 2007
    46
    CH, Lausanne
    Lol, I feel like such a noob. Thank you the info!
  8. Groupcaptainbonzo
    Groupcaptainbonzo TPF Noob!
    Nov 9, 2006
    463
    Turners Hill, West Sussex, UK.
    You will loose all auto functions with a reversing ring. But if you are up to using manual, they are a really cheap way of doing Macro.
    I started off with one, but Now I use a Sigma 105mm f 2.8 EX DG Macro, and use extension rings if required. On its' own it will give 1 : 1 ratios very easily, and even out performs the Canon 100 macro at nearly twice the price....If you get into macro it is well worth a check out..
  9. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    My autofocus works fine when I reversed a 50mm onto a 35-105mm lens. It was probably hard on the AF motor because it had to rotate the whole 50mm lens...but it works. The DOF is so thin...that I end up focusing with slight adjustments to the tripod or subject anyway.
  10. Groupcaptainbonzo
    Nov 9, 2006
    463
    Did you join 2 lenses together. One normally and one reversed ?
    never tried that...
    D.O.F. Is ALWAYS very small indeed. The smaller the macro the smaller the DOF. (I once took a Lady Bird at 1 : 1 and the split in the carapace was sharp. But the front And the back of the carapace were both out of focus..)
  11. Big Mike
    Dec 16, 2003
    33,838
    1,814
    Edmonton
    I sure did. That's the idea of a macro reversing ring.
  12. Groupcaptainbonzo
    Nov 9, 2006
    463
    The reversing rings that I have used, one end fitted the camera, but as they are made of plastic there was no electrical connection to the camera (in my case an old Minolta X-700) the other end fitted the screw in filter thread in the front of the lens (a 50mm f 1.7 Rokor).
    Worked fine, but as I said no auto at all.
coupling ring
coupling ring macro photography
dof da macro
lens coupler
lens coupling
lens coupling ring
macro coupling ring
macro lens coupling
reverse coupling macro
reversing ring
