Helen B
- Joined
- Sep 16, 2007
- Messages
- 3,296
- Reaction score
- 467
- Location
- Hell's Kitchen, New York
- Can others edit my Photos
- Photos NOT OK to edit
i was at the store today playing with a canon 24mm tilt shift on a 5dmkii
i sorta understand what happens now when you shift it up and down, theres really no light when you shift down.
Not sure what you mean. Shifting down ("fall") has the same effect as shifting up ("rise"), just in a different direction. I mostly use fall when taking pictures from roofs, looking down on other buildings. If I simply pointed the camera down I would get converging lines. By holding the camera level and using fall I can look down while keeping verticals vertical.
OK. We are imagining the two cameras in portrait orientation (ie long side of the frame vertical). A 90 mm lens on the 617 and a 17 mm lens on the 35 mm camera. The greater the value of film dimension divided by lens focal length, the greater the coverage.how would my camera have more horizontol coverage than a panoramic camera?
In the vertical (long) dimension:
617 camera - long film dimension = 170 mm; lens FL = 90 mm
170/90 = 1.89
35 mm camera - long film dimension = 36 mm; lens fl = 17 mm
36/17 = 2.12
Therefore in the long dimension the 35-17 combination has a little more coverage.
In the horizontal (short) dimension:
617 camera - short film distance = about 58 mm perhaps; lens fl = 90 mm.
58/90 = 0.64
35 mm camera - short film dimension = 24 mm; lens fl = 17 mm.
24/17 = 1.41
Therefore the 35-17 combination has a lot more horizontal coverage.
(It should be obvious from the aspect ratio of the two frames, without doing that calculation.)
There shouldn't be much. It depends on how good the lens is in terms of distortion. Just remember to make sure that the camera is perfectly levelled.wouldnt my 17mm lens have converging lines from distortion when vertical?
Good luck,
Helen
