lens stopped autofocusing
Discussion in 'Beyond the Basics' started by khallene, Dec 9, 2009.
  1. khallene
    khallene TPF Noob!
    Oct 4, 2008
    121
    Riverside, RI
    Hey everyone, I have the Nikkor 55-200 kit lens and it no longer auto focuses. Yes, I know that in the days days before autofocus, photographers manually focused - I have a 50mm that I manually focus with. It is a Nikon DX AF-S Nikkor 55-200mm 1:4-5.6G ED. I am assuming that it is a problem with the lens and it is most likely going to cost more to fix the issue than just purchase another lens. Any help is appreciated. Thanks.
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Don't feel insulted...but did you check to see if the AF switch has accidentally been clicked from AF to M? (I've don't that 'fix' for a few people)
  3. Pugs
    Pugs TPF Noob!
    Jun 13, 2008
    1,155
    Milwaukee, WI
    Otherwise, the Nikon warranty is solid. I've had a lens repaired by Nikon USA and it was done quickly and I haven't had an issue in the year or so since.
  4. KmH
    Apr 9, 2009
    40,751
    5,588
    Iowa
    That, and what camera do you use because some, like the D90, also have a separate A/M focus switch.
    EDIT: If both switches are in the A position that means it's not working properly and you'll need to send it in to Nikon Service for repair if it's still under warranty. If it's no longer under warranty, it may cost more to repair than the lens is worth. Nikon will give you an estimate before any repairs are made, if there is no warranty.
  5. khallene
    khallene TPF Noob!
    Oct 4, 2008
    121
    Riverside, RI
    Haha....yes Mike, I actually meant to put that in the post, but I got sidetracked while typing as I was feeding my son at the same time! It is definitely still on "A".
    As far as the warranty pugs, I've had it for well over a year. I think the warranty is probably up...
    KmH - it is on my d40x, so no other switch. I did put it on a d50, but sadly, cannot remember if it focused on that camera or not - being that that camera has the autofocus on the body itself.
  6. KmH
    Apr 9, 2009
    40,751
    5,588
    Iowa
    Nikon Service and Repair
  7. khallene
    khallene TPF Noob!
    Oct 4, 2008
    121
    Riverside, RI
    Thanks KmH. I'll check it out w/ Nikon. I've seen a few ads with the VR of this lens on sale, so it may be more cost effective to just go that route.
  8. PatrickHMS
    PatrickHMS TPF Noob!
    Oct 29, 2008
    1,411
    Metro Atlanta
    The little contacts on either the lens, or the camera (but more likely on the lens), might be dirty, not making good contact...
  9. khallene
    khallene TPF Noob!
    Oct 4, 2008
    121
    Riverside, RI
    Any tips on what to clean with? I know I've used a pencil eraser on other contacts - cordless phones and things of that nature.
  10. Eco
    Eco TPF Noob!
    Oct 27, 2009
    315
    Boston MA
    Before sending it off to be repaired you might want to rule out that it's not something with your camera. Try to put it on a friends camera or take it to a retail store and ask them if you can see if your existing lens will work on a new camera.
  11. PatrickHMS
    Oct 29, 2008
    1,411
    Metro Atlanta
    To isolate the problem to either the camera or the lens, try that lens on another camera body, and another lens on that camera body.
    But I should have read the previous post more carefully, someone already thunk of that before I was able to post it.
  12. khallene
    khallene TPF Noob!
    Oct 4, 2008
    121
    Riverside, RI
    Eco and Patrick... I have another lens - the 18-55 and that still autofocuses, that's why I'm assuming it is the lens. I'll take a look at the contacts and see if they are dirty.
    I don't believe the auto focus worked on a d50 that I put it on a while back when this first occurred. I'm almost positive that that camera has the auto focus on the body itself, not the lens.
my nikon lens stopped working
nikon 55-200 wont focus
nikon 70-300 lens stopped focusing
nikon lens stopped autofocusing
