Lens..
Discussion in 'Photography Beginners' Forum' started by Weaving Wax, May 4, 2007.
  1. Weaving Wax
    Weaving Wax TPF Noob!
    Aug 23, 2006
    678
    U.S.
    I've been using my lens for a few months now and am feeling the limitations. I can't get as close as I'd like with some shots. I was thinking of buying a telephoto. Is that the same as a regular zoom? I'd either want a zoom or a telephoto. What should I get? Budget is like less than $200. Anything decent for around that price? My gear is in my sig.
  2. Big Mike
    Dec 16, 2003
    33,841
    1,815
    Edmonton
    Telephoto refers to longer lenses...anything over 50mm really. Zoom refers to a lens that can change it's focal length...from 75-300mm for example.
    That's not much of a budget...but you could probably get a cheap telephoto zoom lens. There are several versions in the 70-300mm range that would fit your budget.
    http://www.bhphotovideo.com/3result...&A=search&Q=&shs=70-300&ci=8429&sb=ps&sq=desc
    http://www.bhphotovideo.com/3result...&A=search&Q=&shs=75-300&ci=8429&sb=ps&sq=desc
    This is the one I have, and would recommend for you and your budget.
  3. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    2,793
    194
    As an alternative why not use your feet to get closer? You may enjoy the perspective. I have a tendency to shoot up close and personal with wide lenses so it is natural for me. Give it a try.
  4. Big Mike
    Dec 16, 2003
    33,841
    1,815
    Edmonton
    Fred makes a good point. Your 50mm lens is a much better lens than any of the ones I listed (in your price range)...and you may be disappointed with the image quality of a cheap zoom...in comparison.
    On the other hand, lens quality seems to be more of an issue with digital (people zooming in a pixel peeping)...since you are shooting film, you probably won't find the cheap zoom too lacking until you enlarge to 8x10 or more (or until you use is in low light).
  5. RedDevilUK
    RedDevilUK TPF Noob!
    Apr 4, 2007
    321
    Rochdale UK (N. Manchester)
    does that include climbing trees and cliff faces???
    NO... get a telephoto lens ;)
  6. Weaving Wax
    Aug 23, 2006
    678
    U.S.
    Well, I'll just save up for a really good lens. The 50mm is good for now. I've gotten some great shots with it. I do use my feet fred, but sometimes you can't get close enough!
    I'll look into getting a flash next. That're more important.
  7. panocho
    panocho TPF Noob!
    Feb 7, 2005
    425
    Compostela, GZ
    just getting closer is a good idea -sometimes.
    other times you just can't, as RedDevil points, or the image you'll get is not precisely what you want.
    It's not the same photographing same subject/same space in the frame with, say, a 35mm and a 105mm. The result will be different, and sometimes you just don't want the one that certain focal distance gives you, so getting closer or further away doesn't help.
    That being said, I do second the advice of using the 50mm. As much as you can. I've always loved having only a 50mm (plus a fully manual camera) and, together with it, the challenge of having to make the picture with a limitation. Sometimes you end up discovering new ways of looking at the things that you would't notice if you had a big range zoom and could photograph almost anything without moving from one single spot.
    Yes, feet are definitely one more "feature" to take seriously into consideration
