Lense question
Discussion in 'Photography Beginners' Forum' started by nightangel73, Jul 22, 2010.
  1. nightangel73
    nightangel73 TPF Noob!
    May 9, 2009
    21
    USA
    Say I have a choice of buying a wide angle lense 18-55mm and a telephoto 55-200mm OR a 18-105mm lense. Which would be better? I would like opinions on advantages and disadvantages
  2. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    First, I believe the 18-55mm is usually referred as Standard Zoom lens while the 55-200mm should be telephoto zoom.
    In general, it is really a personal preference. If I do not want to carry multiple lens and the focal length I use for most of the photos I take fall within 18mm and 105mm, then of course I will choose the 18-105mm lens.
    However, if I often heading to the zoo and would like to take some photos of the animals, 105mm seems too short. so I will opt for the combo.
    Are you planning to buy a DSLR with the kit lens(es)?
  3. sleist
    sleist Been spending a lot of time on here!
    Nov 8, 2009
    3,610
    1,850
    Boston
    All 3 are kit lenses, but are considered to have good image quality, despite being slow and having plastic mounts.
    I have a D90 that came with the 18-105.
    I just bought my son the D5000 which came with the 18-55.
    He's currently using the 18-105, but my plan is to give him back the 18-55, buy him the 55-200, and give him my 35mm1.8. I think that will give him an excellent kit to start with, with a low light normal prime and 18mm - 200mm covered, provided the lighting is good.
    I will keep my 18-105 which has given me some excellent results. If it was one or the other, I would take the 18-55 plus 55-200 over the 18-105 just to get the extra reach. Image quality is comparable between the 3 lenses. You will need/want to add a prime at some point.
    HTH
  4. Robin Usagani
    Robin Usagani Been spending a lot of time on here!
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    18-105mm.. what is the aperture? 18-55mm is always good but I wouldnt pay more than $80 for it.
  5. Neil S.
    Neil S. TPF Noob!
    Jul 16, 2010
    1,128
    21
    Japan
    Do you have any other gear at all? Knowing that would help.
    I started with a 30D and the EF-S 17-85mm kit lens. My 2nd lens was the EF-S 10-22mm, and 3rd was EF-S 18-55mm 2.8.
    I don't recommend people do what I did. I had far too many wide lenses, and no long ones. It was limiting my ability to take certian types of shots.
    I just rescently bought my first long lens, the 70-200mm 2.8L IS II. I realized I should have bought something around this focal length for my 2nd lens.
    So my advice is get a lens that covers 18-XXmm for 1st, and then get one that covers XX-200mm or XX-300mm for 2nd. I am assuming you have no other gear here.
    This is the best way to do it when getting started, unless you really need a super wide lens for your 2nd. I personally find that I don't use my 10-22mm that much, it is very nice to have though.
    Hope this helps.
  6. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    The 18-55mm plus the 55-200mm consumer grade lenses are a really decent buy and covers focal lengths you are most likely to want. That combination with VR on the 55-200mm was my choice when I first started out.
  7. IgsEMT
    IgsEMT No longer a newbie, moving up!
    Jul 27, 2009
    2,694
    49
    NYC
    go for 18-105, boost the sharpness to about 6-7 and enjoy it. If you can, get an 18-200 and boost the sharpness to about 4-5.
    But if you want a really good glass with medium focal range and not to heave on the $, its 24-85 f/2.8-4
  8. SwiftTone
    SwiftTone TPF Noob!
    May 10, 2010
    95
    Boston the BossTown
    What do you mean by "boost the sharpness". Do you mean the setting in the camera??
  9. Rosshole
    Rosshole TPF Noob!
    Mar 23, 2009
    536
    14
    WI
    What do you normally take pictures of?
  10. SwissJ
    SwissJ TPF Noob!
    Mar 29, 2010
    243
    Brooklyn, NY
    Get the 55-200, cause I don't have any lenses in that focal range.
  11. KmH
    Apr 9, 2009
    40,522
    5,537
    Iowa
    Better for what kind of photography?
  12. nightangel73
    May 9, 2009
    21
    USA
    Yes, I'm going to buy new camera (nikon) so I'm at ground zero.
    I never found myself taking too many wide angle shots. My thing is more of portraits and I do want a lense with big aperture because I find myself shooting with available light and low light most of the time. So one lense I want for sure is the a 50mm/1.8. Then I would like to have a telephoto lense and well wide angle shots are nice for traveling and group shots.
