lenses please explain i am confused
miskin83
Hull
Hi I am new could you answer me a question Please If i buy a lens for example 24-70mm F3.5-5.6 what does the f mean?? Does it mean i can i only use the lenses between f3.5-5.6, or can i use them at differnet apertures Please Help i am confused Many thanks
if i got this correct, it means this: if you got the lens on 24mm, the smallest F-number you can use is 3.5. If the lens is set to 70mm, the smallest f-number will be 5.6.
Something like that anyways, but im sure there will be someone more knowledgable then me to come and make it for sure.
Yes that's what it means. If yuo set to the largest aperture at 24 mm it will be 3.5; if you then zoom in to 70mm then the aperture will close to 5.6.
When you zoom the aperture does not change in size, it's just the f-number that changes.
This is because the f-number is given by the focal length of the lens divided by the aperture diameter.
For example:
Aperture diameter = 10mm
At a focal length of 80mm = 80/10 = f8
At a focal length of 40mm = 40/10 = f4
What actually happens is that the light intensity reaching the film/sensor changes due to the Inverse Square Law so the change in f-number compensates for this.
The F-number refers to an aperture, and the number on a lense typically means the maximum aperture the lense can have (in this case, the "biggest" hole your lense can have) for reasons beyond me, but it probably has something to do with the lense's construction. That's why people are willing to pay good money for lense with the widest aperture. E.g, the famous Canon "L"-series lense with its constant F2.8 aperture... :p
In this case, the widest "hole" you can get at 24mm focal length from the lense that you'd mentioned is F3.5. . At maximum zoom (70mm), its F-5.6. Not too bad, but certainly not the kind of lense you would want to stay with if you're a proffesional photographer
Having said that, you can always stop down from the widest aperture of a lense to the smallest aperture (F22?) at any given focal length unless your camera is a point-and-shoot. Digital p-o-s will have vastly limited aperture, I believe.
All F number are the same on all cameras. The F number if a standardized unit.
If there is any terminology you do not understand stroll to the uppermost thread in this part of the forum. After all, we're all about helping. Amen? :lmao:
Hertz - what you're saying is useful, but I think it's way too advance for him. Let him learn step by step before bringing in the big guns :D
I actually thought that what I said answered his question simply and succinctly, but what do I know? ;)
Thanks For all your answers
you have all helped
Miskin83
yeah i thought your reply was fine hertz... and i'm, no pro. i must go have a look at this inverse squares rule though...
Inverse Square Law
Light intensity is inversely proportional to the distance from the source.
Basically saying that the further you move away from the light the darker things get. But there is a set ratio so you can work it out.
Think of Geometry.
Think of a pyramid.
If you have a pyramid (or cone) of a set height the base has a certain base area.
If you double the height of the pyramid the base area increases by a factor of 4.
So too with light.
If you have a light at a known distance from a surface it gives a certain level of illumination.
Move the light twice (2x) the distance away and the illumination level on the surface decreases by a factor of 4 (2 stops).
It's fundamental to virtually all aspects of Photography - but a very simple principle.
That's because it's the same Geometric law that governs both, if you think about it.
Most people miss it.
Some of the strange stuff you learnt in Maths in school does have a use...
Hey. Shhh.
Silly question: what does the letter "f" stand for in "f-stop" then? (I know all the rest, but in German it is called "Blende" and... well... this question is for my English knowledge rather than anything else).
I've seen it written that the f literally stands for fraction. Which kind of makes sense, but is never how I think of it, I always just think of it by its definition.
Focal Ratio is what it was meant to mean at first. First, it was referred to as f-number but f-stop came around when standard ratios became "stops" instead of a graduated number.
That's the way I remember it anyway. ;) :hertz: would know better.
