VincentPaul
- Joined
- Feb 27, 2017
- Messages
- 23
- Reaction score
- 2
- Can others edit my Photos
- Photos NOT OK to edit
Check my answer aboveWhat he said^^^^^. Inquiring minds wonder.
Very good points. As of now yes I would say my main attention has been on what it can do for my edits as it relates to what I mentioned before. I hadn't thought of Astros question in the way you pointed but thanks for pointing that out, I'll remember that when the occassions arrive as I'm sure the possibilities with FS are endless.@VincentPaul I think Astros and Gary were trying to get you to think beyond your initial excitement, to how this process might fit your workflow and how it can be expanded to include just about every editing function available in PS. For example it could be used as part of a selective sharpening process, or by using the curve layer adjustment in conjunction with frequency channels you can drill down and adjust color and Luminosity of your shadows, highlights, or midtones individually. Skin softening is only a small part of what's possible.
Obviously can't speak for everyone but I suspect that anyone who's spent some time in PS is familiar with the process. I will admit there was a sense of wonderment when I first learned. However, I also learned that as with anything, there are always better mousetraps. If you have PS then I'm assuming you have LR. I would highly suggest that you spend some time learning LR, because once you do you'll find less use for PS. In your above example, the skin softening retouching is easily done with an adjustment brush in LR. The advantage is that adjustments made in LR are faster, are none destructive as opposed to PS, and the file size of the edit is a whole lot less. Changing your mind is a breeze.
Will LR replace PS - not at my skill level. I had to pull out the PS tool box on an edit of an orchid recently that needed a makeover, but I'm finding it less and less necessary.
