light flares?
Discussion in 'Beyond the Basics' started by rebecca the curious, Dec 29, 2007.
  1. rebecca the curious
    rebecca the curious TPF Noob!
    Mar 18, 2007
    22
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    without going into serious detail, flares usually occur with light bouncing at an angle to the glass.
    use a lens hood and this should element them. Be sure the hood is the right size for the specific lens.
  3. rebecca the curious
    Mar 18, 2007
    22
    thanks. actually, i was asking because i like them. dont' want to eliminate them.
    is it just a matter of practising to get the right angle at which they occur?
  4. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    They are a result of light bouncing off glass surfaces inside the lens, Lenses with large numbers of elements such as zooms tend to exhibit greater lens flare, as they contain multiple surfaces at which internal bouncing can occur.
  5. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    Wide angle lenses also tend to exhibit flare simply due to the wide angle of acceptance to incoming light. Typically a bright light source like the sun or high intensity street light is needed to create them. Another photographers flash can also do it, but near impossible to control for creative purposes.
  6. ann
    May 14, 2007
    4,263
    189
    well, if you want them to occur, you can try using some gel filters instead of glass without a lens hood, and with the sun at a right angle to the lens.
    you would need to get a special holder for the filters that fits the specific lens your using.
    But as the above writer suggest it is very diffult to control in the creative sense.
  7. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    Crappy UV filters might help...ahaha
    You'll be able to see them usually when you are gonna get em. Just point your lens towards the sun, and move it around until you see some flare. tada!
  8. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Aperture has a big effect on the flare size too. Remember to use the DOF preview when planning to take a shot with flare in it.
  9. Battou
    May 10, 2007
    7,997
    26
    Yes that is a good point, they are generally visible during comp. Knowing that should help creativly use them.
  10. bango707
    bango707 TPF Noob!
    Sep 23, 2007
    124
    Downtown LA
    also the type of lens elements will have an effect on the shape and size of the flare. There are lenses that will produce triangular, circular, square, hexagonal and other shaped flares.
  11. rebecca the curious
    Mar 18, 2007
    22
    interesting. thanks folks.
  12. harshcg
    harshcg TPF Noob!
    Oct 14, 2005
    melbourne
    from my experience if you cut the sun half on your lens it can give you this flare effect. you gotta take a few shots till you get it right.
    i got this at once...
    [​IMG]
first+night photos
flare light in morning
hexagon light photography
hexagon spot on photo
hexagonal flare on photos
hexagonal light specks
hexagonal speck on photo
light flares
light hexagon camera
why are there hexagonal spots on photos
