Lighting and Bounce Diffusers
Discussion in 'Photography Beginners' Forum' started by charles181, Jan 22, 2010.
  1. charles181
    charles181 TPF Noob!
    Jan 21, 2010
    6
    Huntington Beach, CA
    Hey guys. I was looking at several professional portraits, and I couldn't help but realizing the awesome lighting job they do. I know they have some umbrellas tilted probably at 45 degrees on the four corners of the object, but can someone either teach me some cool techniques other than that, or link me to a place that can (in case you don't want to type that much).
    Also regarding bounce diffusers like sto-fen, what're they good for? Is it primarily to reduce the lighting exposed on the subject so it doesn't "ruin the mood"?. Do bounce diffusers serve more of a purpose than that?
    Thanks!
    Also, I want to get into some cool lighting tricks, but I don't have any professional setups. Is there any other alternative I can do with just a 430ex?
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Photography. Photo (meaning light) + graphy (meaning drawing). So photography literally means drawing with light. It's all about light.
    I'd suggest finding some good books on the subject. They shouldn't be too hard to find in a library because the principles of light haven't changed with the digital era, so a 20 year old book on lighting is probably as good or better than a book published two years ago.
    Most of them (Stofen Omnibounce, GF Lightsphere etc.) are meant to be used when you are bouncing the flash.
    Bouncing your flash is probably the easiest way to improve on-camera flash. When it's pointed directly at your subject, the light is rather flat (even) and the size of the light source (flash) compared to the subject, is pretty small, which makes for 'hard' light. But when you aim the flash at the ceiling (or wall etc.) the bounce surface then becomes the light source, which is now much bigger compared to the subject, so you get much softer light. One problem with bouncing light off of the ceiling, is that the light is now coming down onto your subject, similar to sunlight...and this may cause shadows (raccoon eyes for example).
    That's where these flash accessories come in. The Omnibounce lets some of the light go out to bounce, but it also throws some of it forward, directly to the subject and filling in those shadows. A simple bounce card can do the same thing. Some accessorizes, like the lightsphere, throw light in all directions, hoping that it bounces off a lot of surfaces and gets back to the subject very soft. It works well in some situations but is very wasteful in other situations.
    The best thing you can do, to improve your lighting technique, would be to get the flash off the camera. With the flash off the camera, you can use directional light, which allows you to 'sculpt' your subject with light and shadow. With the flash on a stand, you can add useful accessories like an umbrella or softbox etc.
    Read everything you can on THIS SITE.
    Starting with THIS PAGE.
  3. Nic Nube
    Nic Nube TPF Noob!
    Jan 19, 2010
    24
    Africa
    There is so much 'free' light around and its real nice too! I think these gimmicks just cost you an arm and a leg for nothing. sorry mr fong and co
    Shoot where the light is good and make it work for you..whats easier seting up your octa and ranger rx with remote triggers and the works or picking a nice location where the light is as good. studio lighting is great if you live in a cave imo..light is light and if you shooting people you dont need fancy junk imo
    Im not Ansel f adams but Im tired of gimmicks ..the world is a gimmick
  4. AliasPros
    AliasPros TPF Noob!
    Jan 13, 2010
    354
    Central Coast CA
    I use 580exII after my 430 broke... I also love the Gary Fong light diffuser "Cloud" as the light it gives off is so smooth and soft, very little shine on the face even outside of studio such crouded receptions etc... for the price you cant go wrong.
    [​IMG]
    [​IMG]
    Here is the next one I am looking into picking up, the "Whale Tale"
    [​IMG]
  5. ChasK
    ChasK TPF Noob!
    Jan 21, 2010
    102
    Greenwood, IN
    Light is not just light! There are colors, temperatures, umbra, penumbra, feathering, inverse square law, and much much more, but your right, you don't need to buy every piece junk that comes down the road. Long before Fong a simple white index card and a rubber band would do the very same thing. Total cost less than a nickel. Or you could bounce your light off someone's white shirt or a wall even. If you want something that looks better than an index card and rubber band check out dembflashproducts.com. I think you'll find it works at least as good, I think better, for a lot less money.
    Did you know you can cut a hole in the top of a cd/dvd plastic cylinder, throw the spool away, and you have a Fong style light modifier. Get a sample gel pack from B&H for a dollar and you just saved yourself a bout $100 and you'll have a lot more colors to play with. It won't look as pretty (depends on how crafty your are) but you can play with little or no investment.
  6. AliasPros
    AliasPros TPF Noob!
    Jan 13, 2010
    354
    Central Coast CA
  7. Layspeed
    Layspeed TPF Noob!
    Oct 11, 2009
    307
    British Columbia, California & Philippines
    I used an crushed soda can on my back tire :lmao::thumbup:
    I bet the "real" photographer wanted to kick your ass! :grumpy::lol:
  8. WaywardShinobi
    WaywardShinobi TPF Noob!
    Jan 19, 2010
    42
    Louisiana
    As did I, worked much better than a card.
    Speaking of card, I've seen a photographer in my area use card stock in front of a shop light. The shop light was powered with two nine volts, lol. Around here, we use all we can to get whatever job we do done. He's one of only two photographers within an hour or so of me.
  9. AliasPros
    AliasPros TPF Noob!
    Jan 13, 2010
    354
    Central Coast CA
    WOW Santa Barbara and San Louis Obispo California (snooty wine country) is inundated by photographers and they it's an upscale market where you gotta stay up with your equipment (I do pretty well in that respect). I wish I was in an area where I was in more demand. However my equipment is growing and word of mouth has been great since a lot of people already recommend me from my videography also...
    Hmmm... Crushed soda cans huh? never thought of that, it was just easier and more reliable to buy me the 50cc with paper route money... always been a hustler that way. Anyone else feel me on the professional flash diffuser???
  10. keith foster
    keith foster TPF Noob!
    Nov 16, 2009
    508
    10
    Missouri, USA
    There are lots of tutorials out there showing how to get very good shots with a lot of makeshift lighting techniques.
    I think if you can consistently get the results you want and people like it then most folks don't care how or what you used to get it.
    This may not apply to weddings though. I could see a bride passing out if she caught you crushing a beer can to use as a diffuser at the wedding. :lol:
  11. ChasK
    ChasK TPF Noob!
    Jan 21, 2010
    102
    Greenwood, IN
    I wouldn't recommend taking the homemade stuff to a paid gig, could you imagine the look on the Bride's face. Now there's a Kodak moment. The homemade stuff is good to play and learn from without the investment. But taking a bag full of home made junk to a paid event would be about as classy as trying upstage the paid photographer and passing out business cards at an event or wedding.
  12. mrmacedonian
    mrmacedonian TPF Noob!
    Aug 29, 2009
    370
    4
    Columbus, OH
    :thumbup:
