Lighting Kit
Discussion in 'Photography Equipment & Products' started by silver163, Mar 11, 2009.
  1. silver163
    silver163 TPF Noob!
    Mar 31, 2007
    237
  2. Village Idiot
    Mar 20, 2008
    7,274
    406
    Better deal imo.
    Calumet Genesis 200 2-Light Kit - CF0502K1 -
    You can use a sync cable or your pop up flash. They have optical slaves that will pick up the camera flash and fire them. That or radio triggers. The two listed in this thread so far are 150w/s and 200w/s. The pop up flash is something like 15w/s, so it'll be very easy to over power.
  3. silver163
    silver163 TPF Noob!
    Mar 31, 2007
    237
    are they brighter than the first lighting kit i proposed?
  4. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    200 Ws is more than 150 Ws...so yes.
  5. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    But very little. You have to double the power to increase 1 stop (150 to 300 = 1 stop increase)... so even though going from 150 to 200 is more, its less than a 1/2 stop and barely noticeable. Still, more will give you the ability to not so much light brighter as the chance to successfully light wider with the proper modifiers.
  6. Village Idiot
    Mar 20, 2008
    7,274
    406
    But for the extra money you get strobes with digital controls which you can make much more reliable adjustments on rather than using a turn knob. Plus the Genesis lights can use Elinchrom modifiers, which are...nice.
  7. silver163
    silver163 TPF Noob!
    Mar 31, 2007
    237
    which lighting kit is the best for $300?
    can't i just put in better bulbs for higher power?
  8. Village Idiot
    Mar 20, 2008
    7,274
    406
    No. It's probably limited by what the capacitors store and can fire in one burst since 300w/s is not equal to a 300 watt bulb.
    But as mentioned 200w/s isn't much more than 150w/s, it's just the Genesis lights are a much better light imo and they give you something to really build off of.
  9. silver163
    silver163 TPF Noob!
    Mar 31, 2007
    237
    yeah but there is a $100 difference and i am tight on money as is.
    how are they better?
    also cant i just upgrade the capacitators?
  10. Village Idiot
    Mar 20, 2008
    7,274
    406
    Maybe if you're an electrical engineer and know what other components you'd have to replace after you crack open the case...
    Digital controls in 1/10 stop adjustments versus a knob you turn to adjust the power is the biggest thing. That means if you want to turn the power down 4/10 of a stop you press the button until the digital read out shows you where you want to be. On the other lights you turn the knob and hope you get some where close. Unless you have a light meter, you'll never know.
  11. silver163
    silver163 TPF Noob!
    Mar 31, 2007
    237
    i heard someone tell me that 150 and 200 is a big difference for the camera, my camera is a pentax k100d, will it make a difference?
  12. JerryPH
    Oct 14, 2007
    6,111
    15
    Where are you getting yoiur info from? (lol). Light doesn't change by camera mode (you control the amount of light that comes into a camera using ISO, shutter speed and aperture the same in ALL cameras). Maybe he meant something else... but who knows.
    And no, in the end the lighting difference at a picture at 150 vs 200 will be barely visible... you will have to justify the extra cost on other items. VI stated a good example... greater adjustability or greater features, becuase the power diffference between 150 to 200 will be a bit more than a 1/4 stop of light, and thats near not visible.
