lighting technique
Discussion in 'Beyond the Basics' started by silver163, Apr 20, 2010.
  1. silver163
    silver163 TPF Noob!
    Mar 31, 2007
    237
    i know this might be a stupid question but i wanted to know how this lighting technique was performed. namely how were the "hot spots" on the people created, the hot spots are circled in red.
    how can i create those hot spots and yet keep a well light room? i got two B800 alien bees with one shoot through and one reflection lights.
    here are the photos:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    please help
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    It looks to me like those are just the areas that are at the right angle between the light and the camera, and are thus reflecting the most light toward the camera. Also, those appear to be somewhat flat areas and as such, give a bigger highlight area than a more rounded area might.
    I really don't think there is a specific lighting technique in use here.
    The characteristics of light and how it falls onto someone/something...can be controlled/finesses by the light modifiers that we use. A large, (good quality) softbox should give you a nice even light. You can even use just the edge of the light and 'feather' it across your subject, to give it a slightly different feel.
    Also consider that a model's skin/makeup can help to control the highlights on their face/skin.
  3. ghpham
    ghpham TPF Noob!
    Dec 16, 2007
    535
    I didn't think hot spot is a "desired" feature?
  4. mrpink
    mrpink No longer a newbie, moving up!
    Jan 8, 2010
    1,962
    328
    Cincinnati, Ohio
    if you call it a highlight it is... ;)
    p!nK
  5. silver163
    silver163 TPF Noob!
    Mar 31, 2007
    237
    i don't understand what you meant here, can you please explain?
    what about using a large softbox for evening the light out while using a beauty dish to create that highlight?
  6. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Out light isn't often a simple, even wash of light coming from the source/modifier. There is the umbra, which the middle of the light and is usually brightest and then there is the penumbra, which is the are where the light falls off as you move away from the centre and get to the edge of the light.
    In other words, the edge of the light can create a nice little gradient that you can use on your subject, rather than just blasting them with the whole softbox (or whatever).
    It may not make a dramatic difference, but some photographers swear by it.
  7. silver163
    silver163 TPF Noob!
    Mar 31, 2007
    237
    so basically turning the softbox to the side of the model or further away correct?
    would that still maintain the evenness of the lighting in the room or can i just have the blinds open during the shoot and use the softbox to get that effect?
    is that effect possible with alienbees b800 umbrellas?
