Lightning Fast!!
Discussion in 'Critique Forum Archives' started by ClarkKent, Jun 14, 2005.
  1. ClarkKent
    ClarkKent TPF Noob!
    Mar 20, 2005
    2,020
    8
    Kankakee,IL
    Twas a stormy night the other night. How did I do?
    [​IMG]
  2. JonMikal
    JonMikal TPF Noob!
    Jul 28, 2004
    12,262
    327
    lightening is difficult to capture as im sure you know. what technique and settings did you use?
  3. ClarkKent
    ClarkKent TPF Noob!
    Mar 20, 2005
    2,020
    8
    Kankakee,IL
    with this only being my second attempt, I have found out that it is very difficult to capture. What I did was set my camera's iso to 3200 and my shutter speed to 1/60 sec with the aperature wide open, then focus infinity. Then when I would see a flash in the sky...I would shoot away.
  4. tr0gd0o0r
    tr0gd0o0r TPF Noob!
    Jun 29, 2003
    942
    4
    Shreveport, Louisiana
    Try setting your iso to 100, your aperture to the biggest number and clicking and see what you get when the shutter closes
  5. Andrea K
    Andrea K TPF Noob!
    Dec 16, 2004
    2,025
    28
    Philadelphia/North Carolina
    the photo itself is way to grainy and i think it would look better if you had some sort of background like a landscape or a skyline so to add interest
    how is do you capture lightning? ive yet to try it but if i would i would set everything small (iso 100, f20) in order to get the longest shutter speed possible? is this correct in thinking or will the lightning not provide enough light to be seen in a 30 second exposure, im curious as to the best way to capture the lightning.
  6. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    I've used f/16 with 400 and got some OK results with 30 second exposures. They were overexposed and didn't convey the night atmosphere, I think 100 would work better.
    EDIT: I did and search and found a great post on it here
  7. ThatCameraThingy
    ThatCameraThingy TPF Noob!
    Jun 11, 2005
    275
    Bloemfontein, South Africa
    Typically I use ISO 200 - F8 and whatever shutter speed is indicated
    at night you can go 30s or bulb mode and keep it open for up to 5min
    if lightning strikes while the shutter i open - Bingo
    otherwise try again.
    obviously this is assuming the use of a very sturdy tripod
    in day time you are limited by when your photo will overexpose by the ambient light. then F22 will iso 100 , will give you a longer shutter speed. but even then you will be lucky to get 2sec shutter speeds.
    to try and wait ofr lightning and th click away does not always work. I am quite surprised to see the shot you have there.
    happy shooting
    PS - one of my own
    ISO 200 - F22 - 30s Canon EOS 30 (film body)
    [​IMG]
  8. ClarkKent
    ClarkKent TPF Noob!
    Mar 20, 2005
    2,020
    8
    Kankakee,IL
    OOooo...that pretty cool. This was only my second attempt, in total darkness. I have some during the day with the settings that you say that will work. However, during the night, using those settings, I have had some major problems with over exposure. But nonetheless...very good tips and I will be sure to give them a try.
  9. ThatCameraThingy
    Jun 11, 2005
    275
    Thanks Clark
    Glad you like the pic.
    Bear in mind , I'm shooting film. Not sure how a DSLR will react to the setup as I described it. Maybe some of the other DSLR users can comment on that.
    I am now living in an area that has very few lightning spells per year so I can't play as often as I used too.
    Do you play with star trials ??? , wonder how DSLR will cope with that ??
  10. kilifila66
    kilifila66 TPF Noob!
    May 23, 2005
    322
    University Of Nebraska
    I think its not a bad start. I agree that maybe there should be something to show the eyes what scale the lightning was at and also give some sense of the surroundings. You got the right idea, but I do agree low ISO and wide open shutter is the way to be. Look forward to more from ya.
  11. ClarkKent
    ClarkKent TPF Noob!
    Mar 20, 2005
    2,020
    8
    Kankakee,IL
    Ya I thought that because it was dark out that I should use the widest aperature setting that I could. I will defenitely give these tips and tricks a shot next time it storms
