lightshpere or whaletail any good ?
Discussion in 'Photography Equipment & Products' started by THORHAMMER, Sep 17, 2007.
  1. THORHAMMER
    THORHAMMER TPF Noob!
    Dec 24, 2005
    2,789
    8
    Orange County, CA
    anyone use these for portraits or anything ?
    Im thinking about getting another flash so Ill have 2 that I can use in conjunction wirelessly (canon 480ex plus a 580 ) and was wondering If I set them up on stands how cool that would be for portraits and formals.
    Should I see any REAL improvement from the whaletail or lightshpere,
    does the whaletail actually do any good at letting you direct your light
    and
    is the lightsphere just the same as the omnibounce ? I like how its open on top though...
    any ideas, or experience with these products.
  2. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    2,651
    159
    Sorry, Thor, I'm not familiar with these products but, as you know, size of light source is the issue when it comes to softening light for formal portraits. In my experience the light source should be larger than the subject at a normal light to subject distance. Whatever diffusion device accomplishes that would be the way to go. Pretty hard to beat soft boxes and umbrellas. Portrait shooters have been using them for decades.
  3. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    I am a big proponent of Gary Fong's gear I believe the "Whaletail" you mention is a new Fong thing right? I used the last version and got great results from it. If you want to use flashes off-camera a good place to go for some ideas is http://strobist.blogspot.com/ it is really excellent place for all kinds of lessons on off camera lighting using simple flashes and realtively cheap gear with the exception of the Pocket Wizards most of what he uses are relatively inexpensive.
  4. THORHAMMER
    Dec 24, 2005
    2,789
    8
    Orange County, CA
    I should have prefaced... more mobile formals and portraits.
    When your on the move and inside reception halls and running down a field to outpace an overzealous group of people the umbrellas and all that are not so practical anymore.
    I totally didnt mention that. sorry.
    just curious if there a gimmick, or if they can hold their own in a pinch.
  5. JIP
    Aug 29, 2006
    3,019
    Pittsburgh PA
    They do excellent work. Of course they have their place if you can use more extensive lighting go for it but in general they do an excellent job and are well worth the money.
  6. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    They work. They are ludicrously over priced though. I prefer the simple flash card for most situations. Just a larger sheet of inkjet paper rubberbanded or velcroed onto the back of my flash. The advantage is it's cheap and can be customised to suit the situation (different sized cards).
    Down side is you get some stupid looks.
  7. S2K1
    S2K1 TPF Noob!
    Jul 5, 2007
    288
    Utah
    I use the Lightsphere and I really like it. It really softens the light although I've only used it for outdoor portraits so far.
  8. Mike_E
    Jan 26, 2007
    5,327
    264
  9. Big Mike
    Dec 16, 2003
    33,830
    1,812
    Edmonton
    The 'Fong Dong' and his other products can serve a purpose but they are not really a good tool for every situation. Basically they spread light all around...and if there happens to be good surfaces for that light to bounce off of...then you get soft, even lighting. If there isn't something nice to bounce off of...then all you do is waste a good portion of your flash power, which slows down the recycle time and eats up the batteries.
    I haven't watched the videos on his web site in a long time...but I've heard from some knowledgeable people that say that the videos are a complete farce.
    I believe that a good knowledge of how flash and lighting works, will go a lot farther than any particular flash product.
fonggeari
