little help with electricals
Discussion in 'Off Topic Chat' started by gendarmee, Oct 14, 2008.
  1. gendarmee
    gendarmee TPF Noob!
    Dec 30, 2006
    123
    I'm trying too make a terminal for a tubular bulb over a 2 * 2 inch mild steel sheet, using brass terminals.
    I sandwiched the input terminal between rectangular pieces of compact disc (one rivet in the center too attach the terminal too the top piece of disc and 2 more rivets at the edges of the plastic too fix the setup too the metal sheet )
    Now, I used metal rivets, my doubt is whether the pieces of disc would cause a short, because the compact disc has a layer of metal in it(which makes the reflective surface)
    The power source is a 12V 4Amp battery.
  2. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Do you have an ohmmeter?
    Is this what you have (sorry for the crappy drawing...)?
    [​IMG]
    If so, I think the terminal is probably grounded to the plate. Test it with an ohmmeter to be sure.
  3. clarinetJWD
    clarinetJWD The Naked Spammer Staff Member
    May 11, 2005
    5,787
    97
    Houston, TX
    I think you should be alright, so long as you don't short the terminals, but I agree with the Jeep Guy. If you want to do electrical stuff, you gotta have a multi-meter around!
  4. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    If they are in contact with the metal inside the CD I think there's a good chance that it's bonding it to the plate (assuming there is sufficient metal inside the CD for that). You would have to check it with an ohmmeter to be sure though.
    You might be able to rig a little test light up to see if there is any current going from the terminal to the plate.
  5. clarinetJWD
    May 11, 2005
    5,787
    97
    Houston, TX
    You know...on CD-Rs the metal layer isn't on the outside, it's the underside of the top label. Scratch off the edges around the holes/rivets, and no sweat!
  6. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Or you could put some kind of non-conductive sleeve in the hole before shooting/squeezing the rivets. (Sounds like a lot of work either way.)
    The easiest solution would probably be to find some material other than a CD to use...
  7. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
    It's only 12v, try it and find out seeing as you've already made it. You could always try an epoxy resin to build it. No contacts and visible joins. Don't know of any brand names in the US but go to any DIY shop or place which sells car parts and you'll find some for under £5 ($10). Rapid stuff isn't normally as strong - just in case you wanted to know and are thinking to other uses for it.
  8. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    You're making 60 of these?
