Location Lighting Without Electrical Outlets?
Discussion in 'Photography Equipment & Products' started by The Phototron, Jan 5, 2008.
  1. The Phototron
    The Phototron TPF Noob!
    Jun 26, 2007
    948
    Is there any way to use a powerpack like Speedotron 805 on locations without electrical outlets?
    Second question, are there any public electrical outlets on the streets (I live in NY)? If any at all?
    Thanks for taking time to read this. I have tried to find the answer, or just in denial to the fact that I fail to perceive the difference between a powerpack and a battery-powerpack.
  2. jwkwd
    jwkwd TPF Noob!
    Oct 26, 2005
    630
    Western N.Y.
    I know that there are converters that you can run from a car (DC to AC). I imagine it would depend on how many amps you need. If you are concerned about recharging batteries, those would work. If you need to power a large lighting system, you would be out of luck. I think that if New York had public outlets, you could find them by looking for all the homeless people gathered around watching TV. My definition of a powerpack would be a generator that provides 120 volts AC. Again to me, a battery/powerpack would be the thing that you stick in your camera to make it work.
  3. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
  4. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    Are there any public outlets on the streets??? you live in NY??? NY i a pretty big place. In the whole state yes, I igine there are some public outlets somewhere but it depends on where you go. Parks have them other places do but to ask if there are public outlets in NY is a pretty broad question. There are battery packs available for studio lighting do you have any lights right now. If you do not have a system right now (or even if you do) you might consider some of the things in The Strobist http://strobist.blogspot.com/ might be a good place o go for a decent alternative to carrying a whole studio systemwith you when you go out on a location shoot. He (The Strobist) works with speedlites instead of studio lights and gets wonderful results with a kit you can carry in a tripod bag.
  5. The Phototron
    Jun 26, 2007
    948
    By New York I mean Manhattan area or NYC. I just this guy using an electric outlet from the base of a street light on youtube (the video on how easily it is to steal a bike). He just take it right out and plug it onto his equipment, but I was wondering would you need some kind of a permit to use them.
    I have tried the strobist approach, and have a vivitar 285HV, but for now I want to focus on the studio set I bought. I will go with the strobist for portability, but studio strobes are good for many other reasons. And while I do not have the background to contest that, I have to get familiar with them for a future class anyway.
    The set I have now consist of a Speedotron Black Line System:
    (1) 805 power pack
    (4) 103 universal flash heads
    I plan to sell 2 of those heads, since I really don't need that much now and the money could be better spent elsewhere.
  6. JIP
    Aug 29, 2006
    3,019
    Pittsburgh PA
    Well if you go to the Speedtron site http://www.speedotron.com/BlkPack.htm you will see right on their front page they have a portable location power-supply. If you look at B+H you will see they have it available for around $1700 http://www.bhphotovideo.com/c/product/518767-REG/Speedotron_11256_1500_W_S_Digital_Explorer.html . Or you could try a gas powered generator. Your suggestion of outlets is going to be very touch and go if you are going to depend on that I would do some serious scouting of your location before you go out for a shoot with a model/client and all your gear in tow. I think generally it is going to be hard to find but I am sure you will find some places.
  7. table1349
    Sep 9, 2006
    Ok, apparently I'm not smarter than the link. Here is where it should have lead.
    [SIZE=+1]Introducing -
    The Speedotron Explorer 1500 Digital Portable Power Supply,
    [/SIZE]
    [SIZE=+1]the latest Black Line System innovation. [/SIZE][SIZE=+1]Priced economically at $2100, the Explorer provides a cost effective solution to gas powered generators or high priced European portable systems for those location shots where electrical power is not available.[/SIZE]
    [​IMG] [​IMG] [​IMG]
    [SIZE=+1][/SIZE]The Explorer 1500 portable battery provides for up to 225 full power flashes and may be quickly replaced with a spare battery, "The Juice Box" (#11253) priced at $400. Each battery contains a universal recharging circuit which draws only 1.3 amperes max from 85 to 265 volts at 47Hz to 63Hz. The Explorer 1500 Digital can use electric current from nearly anywhere in the world without voltage adapters. The low current draw even allows recharging batteries with an inexpensive inverter connected to a car's accessory outlet!
    9.5" x 5.4" x 11.7", 24.8 lbs.
  8. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    For the location, unless you REALLY need to block out the sun, speedlights are the far superior way to shoot, Especially if you have easy means to trigger them wirelessly, ala CLS.
  9. The Phototron
    Jun 26, 2007
    948
    I guess that settles it, strobist for locations I can't get access to electric outlets, and studio strobe for place that I can.
    I think it has been argued before, but studio strobes simply have more modifiers. Although that is probably going to change in the future.
  10. JIP
    Aug 29, 2006
    3,019
    Pittsburgh PA
    Now now now there is nothing wrong with my link it works just fine. Also to Phototron if you tihink studio lighting has more modifiers than Strobist style speedlite shooting you need to read more of The Strobist site.
  11. The Phototron
    Jun 26, 2007
    948
    Yes, that is what I think until proof wrong. I do visit the strobist site every now and then, and I see a lot of DIY stuffs, but that's not what I'm referring to.
  12. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    That's BS, anyone who isn't lazy enough to do at least a little DIY can do anything with speedlights that you can with studio strobes.
