Long exposure setting for Canon 20D?
Discussion in 'Digital Discussion & Q&A' started by seemoo, Dec 7, 2006.
  1. seemoo
    seemoo TPF Noob!
    Oct 4, 2006
    184
    Glendale, CA
    Hi
    I recently went on a camping trip and wanted to take some long exposure pictures of the stars. I use the Canon 20D and I noticed that the longest exposure in Manual or Shutter Priority is 30sec. (it also has the "bulb" setting, but that requires keeping the button pressed; not very good for stable images)
    Is there a way of setting a longer custom exposure (for example 1, 2, 5 or 10 minutes)?
    Thanks a lot for your help.
    simon
  2. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    Bulb mode with a [FONT=Verdana,Arial,Helvetica,sans-serif]Canon Remote Switch RS-80N3 or a [/FONT][FONT=Verdana,Arial,Helvetica,sans-serif]Canon Timer Remote Controller TC-80N3 if you want to spend big bucks.
    [/FONT]
  3. seemoo
    seemoo TPF Noob!
    Oct 4, 2006
    184
    Glendale, CA
    thank you for your quick reply.
    wow, very expensive for such a simple piece of equipment. It seems to me that all those functions should already be included in the camera's software from the beginning.
    So what's the difference between the $50 the switch version RS-80N3 and the cheaper RS60 E3 ($17). Does anyone have some recommendations?
    thanks again
  4. David
    David TPF Noob!
    Aug 22, 2006
    96
    11
    Suffolk, UK
    If you have a 20D you'll need the RS-80 N3, because the RS-60 E3 has a different 'plug' and is therefore not compatible. The 60 was designed as I remember to be compatible with the EOS 300 and 350 cameras, whereas the 80 is designed for the 1D's down to the 20d.
    The 80 N3 is worth the money, and has a lock down feature so you won't have to stand around and hold it for those long exposures.
    David
  5. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    All you need is a remote with a lock down switch and a watch. I got one on E-bay...Adit was the 'brand' and it was made in China. It's not very robust...but it was cheap and it does the trick.
canon 20d long exposure
canon 20d long exposure settings
canon eos 20d long exposure
canon eos 20d slow exposure
how to do a long exposure shot on a eos 20d
long exposure nikon eos d20
long exposure on canon eos20d
long exposure photography canon eos 20d
long exposure setting canon 20d
