Looking for a few suggestions...
Discussion in 'Beyond the Basics' started by Tsunami1981, Jul 7, 2003.
  1. Tsunami1981
    Tsunami1981 TPF Noob!
    Jul 7, 2003
    19
    Minneapolis Minnesota
    Currently I have been shooting alot of sporting events ( i.e. hockey games) for my husbands' hockey team... I am having a problem with graininess with some of my pics. I am shooting with a Nikon N80 most of the time and using a tamron 70-300mm. I contacted the photographer for the Star Tribune and he suggested using faster speed film, so I bumped up to 1600 and that helped a bit, considering the lighting in these arenas is kind of crappy. Any suggestions would be greatly appreciated.
    I have gotten some great shots but it is really depressing when the pic doesn't turn out as well as it should.
  2. metroshane
    metroshane TPF Noob!
    Apr 30, 2003
    615
    I think the new photographer misunderstood you. A faster film would be the obvious recommendation if your pics were blurry....but faster usually = grainer.
    If you have enough light, try going down to 400 or so film.
  3. Tsunami1981
    Jul 7, 2003
    19
    thanks for the suggestion.. i will try it and see what happens.
    **crosses fingers**
  4. e_
    e_ TPF Noob!
    Jun 20, 2003
    177
    ...... itinerant ..........
    ...metroshane is correct in that faster film "usually" equals more grain
    However, in and of itself, faster film (or film that's pushed) should not be grainier to the extent you are "having a problem with graininess"
    I suspect something else(*) is the reason - more likely incorrect exposure of the film, maybe combined with faulty development (times and/or chemicals)
    You might like to post details of the following:
    What film/s are you using? What speed are you rating it at? How are you metering your scene? When shooting, what 'mode' do you use (or, what aperture do you use)? How is the film developed?
    e_
    (*) EDIT: what i suspect - although it's only speculation, you haven't answered back as yet ;) - is exposure technique
    If you are metering through your lens (TTL) onto an ice rink, the meter will be reading all of that white ice and "underexposing" (possibly by up to 2 f-stops!)
    Should that be the case, your lab will be correcting for this when printing and a common result with colour film when that happens is an unacceptable "graininess"
    If so, it's easy to adjust for in camera
    Look forward to your post...
  5. nikon90s
    nikon90s TPF Noob!
    Jul 5, 2003
    581
    Kalispell, MT.
    I would use 400 also, but I tend to use 400 alot. It work well with sports and bad light.
