Looking for cheap external flash.
Discussion in 'Photography Beginners' Forum' started by anubis404, Aug 19, 2008.
  1. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    Will all hotshoe flashes work with my D40? Or are some electronically incompatible? Lets say my budget is $75. Is there any cheap external flashes available in this range?
  2. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    Most modern flashes will work with your camera at least in the manual mode, however you won't have TTL flash-metering. Before you use any flash that is not listed as Nikon-compatible, ensure you do some research and verify that the trigger-voltages are appropriate*. If you're on a serious budget, look for used Sunpack or Sigma flashes which are Nikon compatible.
    *Translation: I strongly recommend against using a flash which isn't meant for Nikon, but many will work to some extent.
  3. Village Idiot
    Mar 20, 2008
    7,274
    406
    Sunpak 383 - $80
    Fully manual though.
  4. Village Idiot
    Mar 20, 2008
    7,274
    406
  5. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
  6. Village Idiot
    Mar 20, 2008
    7,274
    406
    But if the manufacture says it's safe and you find out the flashes voltage rating and it's within spec, then there's no downside to using it.
  7. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    Sunpak also makes dedicated units for Canon and Nikon with different price ranges.
  8. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    Two words: Waren Tee.
  9. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    One thing to look for in even cheep flashes is the ability to adjust output. Many don't which is pretty limiting. Make sure trigger voltages are not too high... but if your camera says 250V is fine then ok but I personally wouldn't trust it. As already posted, auto TTL anything is probably not going to work with these flashes.
    I like my Sunpak 422D that gets used on many of my cameras both Digital and Film. Trigger voltage is low, swivel, tilt, and power is adjustable via a slider. The only bad thing about it is that it doesn't have a zoom head.
  10. Village Idiot
    Mar 20, 2008
    7,274
    406
    But if it's withing spec, it'll work fine and you won't have any problems with it.
    You guys are paranoid. Is it that or do you not trust that the manufactures know what they're talking about?
  11. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    I agree. Most of the true flash voltage ruining DSLRs stories come from the 6 volt rating of the Canon 10D. Canon has recognized that was a mistake, and gone back to 250 volt ratings. I've been using Vivitar 285HVs on 20Ds, 5Ds, and 40Ds with no problems.
  12. Village Idiot
    Mar 20, 2008
    7,274
    406
    I kept hearing all these horror stories about how you'll ruin your camera with anything over 6v and that all digital cameras can only survive less than 6v. I went poking around and found out that was true...five years ago. Pretty much everything after the 10d on Canon's side is rated at 250v and I think d50+ on the Nikon side.
