Looking for Framing Advice
Discussion in 'Photography Beginners' Forum' started by hankejp, Jun 6, 2009.
  1. hankejp
    hankejp TPF Noob!
    Aug 24, 2008
    608
    Wausau, Wisconsin
    So I got one of my shots blown up to a 20x30 and now I am loking to frame it. What I'm thinking to do is to not have glass in front of the picture. Basically just the frame around the photo. Would it be best to use some sort of adhesive to "stick" the photo to the the backing?
    If so, what type of backing would I use and what would you use for the adhesive. This is the 1st time of doing something like this.
    Or would you just frame it without the glass? I think that if I were to do that, the picture wouldn't stay flat against the backing.
    Thanks everyone.
  2. Ptyler22
    Ptyler22 TPF Noob!
    May 23, 2008
    789
    Massachusetts
    I would put it in the frame first, and see if it will lay flat, and then if it doesn't, you could always use some double stick tape, its sticky enough but not too sticky.
  3. Bitter Jeweler
    Bitter Jeweler Been spending a lot of time on here!
    Apr 27, 2009
    12,984
    4,971
    Cleveland, Ohio
    You could take it somewhere and have it mounted fairly inexpensively.
    If you want to do it yourself, and are not concerned about archival quality, just use spray adhesive on foam core. Be careful you don't get bubbles with a piece that size.
    I could ask my professional picture framing partner for other options for you.
  4. hankejp
    hankejp TPF Noob!
    Aug 24, 2008
    608
    Wausau, Wisconsin
    That would be great Bitter. I would've gotten it printed on Masonite, but I didn't want to pay that much. About $170 for that size.
    Thanks
  5. KmH
    Apr 9, 2009
    38,479
    5,084
    Iowa
    The print mounted with spray adhesive on foamcore will last about 20 years. The foamcore will deteriorate and get crumbly as it gets asaulted from both sides, everyday air pollution on the back adding acid and the front side by the spray adhesive. The acid the foamcore absorbs from the atmosphere and the aging of the spray adhesive will, in time, discolor the print too.
    You can mitigate that somewhat by having the print dry mounted on Gatorboard.
  6. Bitter Jeweler
    Apr 27, 2009
    12,984
    4,971
    Cleveland, Ohio
    My partner, who is a pro framer (as opposed to Micheal's or other cheap places), re-iterated what KmH said. That's your best, cheap option, and they would do it for you for $20. He said if you want it to last longer UV glass, and sealing the back extends the life much longer. He said going the foam core/spray mount route will get you the same life out of the print as if you did nothing, and exposed the print to the environment.
    Hope that was helpful.
  7. Christie Photo
    Christie Photo No longer a newbie, moving up!
    Jan 7, 2005
    7,006
    67
    Kankakee, IL
    Holy crap! The lab I use will dry mount that size on Masonite for under $24.
    -Pete
  8. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    Ya, that doesn't sound right. I had some 10x30 prints done up. With printing, mounting on Masonite and even finished edges (so it doesn't need a frame), it came to about $50 CDN.
  9. hankejp
    hankejp TPF Noob!
    Aug 24, 2008
    608
    Wausau, Wisconsin
    Does anyone have any websites that does Masonite printing? I've looked all over where I live and no one does it. I'll have to find that website again with that price.
    Thanks
  10. Christie Photo
    Jan 7, 2005
    7,006
    67
    Kankakee, IL
    Now.... the printing isn't done right on the Masonite. It's a print that gets "dry mounted" onto the Masonite. Right now, I'm using Meridian Professional Imaging. I've been using them for just 6 months now, and am still working on getting exactly what I want. The customer service is good and the pricing is very good.
    -Pete
  11. hankejp
    hankejp TPF Noob!
    Aug 24, 2008
    608
    Wausau, Wisconsin
    Thanks Christie. I was under the impression that the photo was printed right onto the masonite. I got this from a guy around here whose wife own a gallery and said the work was printed on masonite. So I will have to check out dry mounting onto masonite.
    I'll check out the website you provided.
    Thanks again.
  12. hankejp
    hankejp TPF Noob!
    Aug 24, 2008
    608
    Wausau, Wisconsin
    Yay for me. I just found out that Digicopy does dry mounting here in my town. It'll cost me $23.00 for a 20x30 print.
    Thanks everyone.
