Looking for help
Discussion in 'Photo Assignments & Technical Challenges' started by 5harkie, Jun 7, 2017.
  1. 5harkie
    5harkie TPF Noob!
    Jun 7, 2017
    Hi all,
    I recently went on holidays to the UK and when I returned I downloaded all my pics and the majority were fine. Except the images I took around water as I like to have the feathered look especially when there is a waterfall. I took around 30 images in two separate locations spanning several weeks, used the same lens & tripod. Out of the 30 feathered images only one or two worked, the rest were partially blurred. Ive done this numerous times over many years and this is the first time this is happened. I'm hoping someone with more knowledge than me will shed some light on this disappointing issue.
    The only changes between this time and others was I purchased a new lens. My camera is old but still working fine, unless this is the first indication of it going bad. Its a Nikon D70S
  2. Ysarex
    Ysarex Been spending a lot of time on here!
    Nov 27, 2011
    5,427
    2,397
    St. Louis
    Is the new lens a VR lens? That would explain it.
    Joe
  3. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    And was the VR turned on?
  4. 5harkie
    5harkie TPF Noob!
    Jun 7, 2017
    Hi guys,
    Thanks for getting back to me. The VC button was turned on, I'm guessing this is the VR??
    My old lens did NOT have this.
  5. Cody'sCaptures
    Cody'sCaptures No longer a newbie, moving up!
    Jan 31, 2017
    210
    76
    Chicago
    It's called vr on Nikon.. VC on Tamron..
    Turn it off when on a tripod, keep it on pretty much all other times.
  6. KmH
    Apr 9, 2009
    40,544
    5,541
    Iowa
    Actually, most of the time you want VR/VC/IS off.
    Image stabilization systems in the lens can't react fast enough at shutter speeds from about 1/500 and faster to provide any benefit.
    Leaving VR/VC/IS on is an unnecessary power drain on the battery.
    Turn it on when your shutter speed is less than 1/500
