Lost edits in lightroom
Discussion in 'Photography Beginners' Forum' started by Moe, Sep 7, 2009.
  1. Moe
    Moe TPF Noob!
    Nov 19, 2008
    383
    7
    Kauai, Hawaii
    I'm going to try to make this sound as uncomplicated as possible.
    In an attempt to get more organized with backups, etc, I started a system of putting photos from memory card to a desktop folder with the date. I then edit them in Lightroom. My plan was to then put the folders into one folder, titled photography, then put them on a hard drive after backing up to dvd. One folder contained photos from a wedding. That folder had photos from the first memory card and a folder within it with photos from a second memory card. However, after moving them and telling LR where the photos were from the first memory card, it lost photos from the second memory card. I have the original RAW files, but LR doesn't have the edits. I tried "undo" to no avail. Am I screwed? Do I have to go through and re-edit?
    Thanks in advance, and I hope that was pretty clear.
  2. thenikonguy
    thenikonguy TPF Noob!
    Jul 26, 2009
    589
    uh oh.. this happened to me.. i know there is a way to fix it.. I just cant remember what.. at the time, I just ended up re editing.. but, I read somewhere recently about the file that contains the edits.. hopefully someone chimes in to help you out..
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Your workflow with the file movement, doens't sound like a good one.
    I'd suggest putting the files where they are meant to end up, then do your work in LR.
  4. thenikonguy
    Jul 26, 2009
    589
    I agree 100% with mike on this one.. its silly to edit the photos, THEN move them... put them where they belong, then start your editing
  5. KmH
    Apr 9, 2009
    40,561
    5,547
    Iowa
    Your edits are stored in 'sidecar files' and you probably didn't move the sidecar files along with the RAW files. Your edits (the sidecar files) are back in the folder where the RAW file was when you did the edits. If you deleted the sidecar files your edit info is gone unless they are still sitting in the recycle bin.
  6. Moe
    Moe TPF Noob!
    Nov 19, 2008
    383
    7
    Kauai, Hawaii
    I realize it's not the best workflow. However, I have a laptop and didn't want to be plugged in to the external HD while editing. I thought LR should be able to handle the move.
    By the way, the wedding photos were not a paid gig. Far from it. Just a guy in the crowd with a DSLR. It was a beach wedding with about 50 people in attendance. No joke, there had to be at least 8-10 people with DSLR firing away. I wasn't even going to bring mine out, but I thought, "when in Rome." :lol:
  7. Moe
    Moe TPF Noob!
    Nov 19, 2008
    383
    7
    Kauai, Hawaii
    Thanks KmH. I'll check it out when I get home from work.
  8. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    It can...as long as you know how to do it properly....which (I think) is to either do it in the Library module of LR or if you are doing it externally, make sure you move the sidecar files.
    You shouldn't have to. Lightroom can edit photos without actually having access to the files. (although you may have to pre-load the full size previews). Just import the files from the HD, then when you disconnect the HD, they should still show up in LR...but there will be a red light (or some icon) next to them, showing that LR doesn't have access to the files (or doesn't know where they are). When you plug the HD back in, LR should then recognize them again...and I think it will automatically sync up the edits.
    Lastly, doing photo editing with a laptop isn't recommended. ;)
  9. Moe
    Moe TPF Noob!
    Nov 19, 2008
    383
    7
    Kauai, Hawaii
    I wondered how long it would be until someone commented on my editing the photos on a laptop. Hey,trust me, if I thought the limiting factor in my photographs was the monitor on which I edit them, it would be quickly replaced; as would my camera, lenses, etc. I wish it were that easy. :lol:
    Thanks, Mike, for the info. I guess that's what I'll do from now on. I just got the laptop about a month ago and I'm already spoiled on the portability.
    It's no big deal that I have to re-edit. I'm basically doing it for me, anyway.
    Another couple questions. Once I sync up the edits, am I able to export them without reconnecting the HD? Also, are the sidecar files in the same folder as the original RAWs?
  10. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    I don't know...but my guess would be no. Exporting takes a while because that's when LR access the original files, applies the edits and saves/outputs the new image files.
  11. GeneralBenson
    GeneralBenson TPF Noob!
    Mar 28, 2008
    1,106
    18
    Boulder, CO
    So this isa question I've been confused on for a while. all my images are on an external HD. Originally I thought it would be good to havethe catalog also on that HD, because I have multiple laptops, and then either one could be plugged in and work in that catalog, but as it turns out, I only use one laptop (the faster one); and as the OP found out, I can't work on the files without being hooked into the HD. Should I move the catalog onto my Laptop HD and then just have the files on the External HD? Sorry if this is a hijack, but it seemed to be pretty in linewith the OP's question.
  12. Moe
    Moe TPF Noob!
    Nov 19, 2008
    383
    7
    Kauai, Hawaii
    So I haven't had time to fully decide my edits are gone, but I found out (I think) that lightroom does NOT automatically store sidecar files. You have to go under catalog settings and check a box. FYI, for those who are interested.
