LumoPro LP120 Manual Flash?
Discussion in 'Photography Beginners' Forum' started by ababysean, Jun 5, 2010.
  1. ababysean
    ababysean TPF Noob!
    Apr 29, 2010
    1,965
    103
    Pensacola, FL
  2. KmH
    Apr 9, 2009
    39,501
    5,330
    Iowa
    It's cheaper because it can't do as much as a SB-600. It works well as an OCF radio triggered speedlight.
    Your link shows the LP120 has been discontinued.
    Do you understand what the GN rating is telling you about speedlight power output?
    Guide number - Wikipedia, the free encyclopedia
    Look at the Vivitar 285HV: Vivitar | 285HV Flash | 233965 | B&H Photo Video if you're not going to start with a SB-600 (recommended)
  3. Melesse
    Melesse TPF Noob!
    Jan 28, 2010
    22
    Culpeper, VA
    Yea, the LP120 has been replaced with the LP160.
    Depending on what you want, it is an excellent flash. It is a flash designed for strobist work, and is set up completely manually (unless they changed things significantly with the 160). If you want a manual flash, then this one is ace.
    If you want a flash to put on top of the camera to fire and forget, or use TTL of any kind, than this is not the flash for you.
    Mel
lp120 manual flash user guide
lp160 vs 285hv
lumopro 120
lumopro lp120
lumopro lp120 gn
lumopro lp120 manual
lumopro lp160 or vivitar
lumopro lp160 vs vivitar
lumopro lp160 vs vivitar 285hv
lumopro vs. vivitar
