M42 Adapter Arrived But Lens Has Fogging (Insight Requested)
Discussion in 'Photography Beginners' Forum' started by AgentDrex, Sep 18, 2010.
  1. AgentDrex
    AgentDrex No longer a newbie, moving up!
    Jan 27, 2008
    2,837
    405
    Bemidji, Minnesota, USA
    Well, the adapter to hook up the M42 mount lenses I have came in the mail Friday. So I took it out and did some shots. What could be the cause of the foggy look you'll notice in the following photos? I cleaned the outside of the lenses after noticing the aberration but no change in the fogging was noticed. I'm thinking it may be on the inner-side of the lens. Could this be possible and what, if any, options do I have to get rid of it? Here are a couple photos for examples-sake:
    #1 My buddy Tron - Notice the translucent edge around his sweater
    [​IMG]
    #2 - I'm sure you can see the birds glow around the edges as well...
    [​IMG]
    #3 - This time I notice the tree-tops have a glow...
    [​IMG]
    #4 - And finally, the foggy look, the white balance I was using, and the position of the sun in relation to the rest of the photo lends itself well to an old look...but still...kind of annoying...
    [​IMG]
    Well, there ya go, I screwed up more photo chances and this morning was so beautiful. Maybe my best bet is to buy another old Haminex and see if it behaves the same. I already know I can find them cheap enough to not worry about losing too much money.
    The fogginess does seem to fit the mood of some of the photos, but these ones not so much so...any help would be kindly appreciated. Thank you advance for any assistance.
  2. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,515
    15,230
    USA
    The lens is probably suffering from fungus growth inside, or perhaps outgassing from having been stored in say, a wooden dresser drawer, or in a case or trunk with foam products made with a petroleum base...the foam padding in many filter cases, protective cases, etc,etc, can outgas or off-gas,and that can cause a thin film on lens surfaces, filters,etc.
    You have a nice soft-focus lens now...it's hard to fake this same,exact effect in precisely the same way...it actually will look good with the right subject matter and the right type of lighting.
  3. KmH
    Apr 9, 2009
    40,762
    5,588
    Iowa
    If it is a prime lens, you have the inclination, and you have a modicum of mechanical skill, you could disassemble and clean the lens.
  4. AgentDrex
    Jan 27, 2008
    2,837
    405
    It is a prime (135mm), I have a small amount of mechanical skill and some inclination to do some repair to be sure...what would be the typical cleaning scenario? Or I can just leave it, might lend well to soft looking flower shots...
  5. AgentDrex
    Jan 27, 2008
    2,837
    405
    I'll have more photos with these lenses posted tomorrow. My first moon shot will be included...
  6. sobolik
    sobolik TPF Noob!
    Jan 1, 2006
    675
    Since you did not identify the lens details let me take a random shot at solving. If it is moisture inside the lens remove it with a vacuum pump. One like they use for refrigeration.
    I do it often to remove moisture from watches, cell phones etc. Use a thick piece of plastic to make the "bag" Set the suction hose near the lens so that the suction sealed bag does not seal off the hose from the lens. The water will boil at room temp and be sucked out any small cracks in any seals. Many old hunting scopes suffered from the same fogging years ago until technology developed better seals.
  7. enzodm
    enzodm No longer a newbie, moving up!
    Sep 5, 2010
    1,509
    118
    Italy
    Is that at wide open? Try also to close a little (5.6 or so). Do you have filters in front? I lost a number of pictures because I didn't check my UV filter, and it was very dirty... same effect.
    You could look through the lens, wide open, to understand whether there is something strange. However, the flou effect is really strong.
    If the lens is a 135mm, you may find disassembly guides around. This is for Pentacon: http://frozenfate.blogspot.com/2010/08/disassembly-guide-for-pentacon-135mm.html . I anticipate the most "difficult" thing to do is to unscrew rings if you do not have, like me, a spanner wrench. And lots of care, before trying read accurately about lens cleaning,, in case fungus cleaning (that is different), etc.
  8. AgentDrex
    Jan 27, 2008
    2,837
    405
    I posted photos of the lens in a different thread. As for the filters, I did check them and clean them along with the parts of the lens I can get at, all to no avail. Its just the one lens like that, unfortunately for me, its my 135mm...I am starting a new thread for some C&C action now...I'm going to buy a few more used lenses from ebay and see how my luck turns out...
    Thanks for all the insights guys! Much appreciated...
  9. Derrel
    Jul 23, 2009
    40,515
    15,230
    USA
    I say keep the lens as a soft focus effect lens...and buy another, clean 135/2.8.
  10. AgentDrex
    Jan 27, 2008
    2,837
    405
    Roger that! I had that same idea considering the crabapple photo I posted in an earlier thread...
  11. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    That's probably the best bet. Also, I remember hearing that fogging can be caused by lens separation, too.
  12. enzodm
    Sep 5, 2010
    1,509
    118
    Italy
    did you just look through?
