Macro attachments
Discussion in 'Photography Equipment & Products' started by neogfx, Mar 22, 2007.
  1. neogfx
    neogfx TPF Noob!
    Nov 21, 2006
    387
    OK, I am in need of some macro ability for my 350D. I am a hard-up student and have next to no money, so can't afford a really nice macro lens. I saw these and was wondeering if anyone else had used them and what they thought.
    Advice on this would be most appreciated.
    Thanks.
    http://cgi.ebay.co.uk/ws/eBayISAPI....MEWA:IT&viewitem=&item=230105286694&rd=1&rd=1
  2. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    It's not my favorite way to get into macro, but they will work. I prefer extension tubes.
  3. Orgnoi1
    Orgnoi1 TPF Noob!
    Aug 22, 2006
    481
    Upstate NY
    I am not a huge fan of the filters either but it really depends on what you can spend...
    I would definately look into extension tubes... you can get a single tube for around $60-80 or $160 for the set of three and it will work with any of your lenses... generally the cheapest and easiest way to get into macro shooting is with the Canon 50/1.8 and 20mm kenko tube...
    http://www.adorama.com/CA5018AFU.html
    and
    http://www.adorama.com/MCET12EOS.html
    http://www.adorama.com/MCET25EOS.html
    http://www.adorama.com/KNAETSDEOS.html
  4. neogfx
    neogfx TPF Noob!
    Nov 21, 2006
    387
    So an extension tube just allows you to plug your existing standard lens straight into the end for a macro equivalent? Does it enable you to use your autofocus and camera TTL meters as normal?
  5. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    The extension tubes go between the lens and the body, and just move the rear of the lens further from the film/sensor. It enables you to focus much closer than normal. Autofocus and TTL metering should work fine, but it probably depends on your camera. I use a set of 3 Kenko extension tubes with my Canon 20D and I have AF and metering. AF is really unusable though, because you do lose quite a bit of light with tubes, and the DOF is so shallow, that you really need to manually focus.
  6. neogfx
    neogfx TPF Noob!
    Nov 21, 2006
    387
    OK, thanks very much for your help guys. I'll have a look at these systems and see which suits me best.
    Thanks again.
  7. TomHuck-wa
    TomHuck-wa TPF Noob!
    Jan 20, 2007
    81
    South central Washington state
    With the Kenko tubes the autofocus on the 20D still works. With another brand the autofocus does not work on the EF lenses.
