Macro Lens for an XTi weilding Newbie.
Discussion in 'Photography Equipment & Products' started by Dradd, Mar 30, 2008.
  1. Dradd
    Dradd TPF Noob!
    Mar 28, 2008
    40
    Heya Guys,
    Sorry if this in the the wrong place...still a TPF newbie (and relative photography newbie at that)
    I was hopeing for a little advice about what is a decent Macro lens for a Canon 400D.
    From the looking around I have done, it would seem my options are something like:
    Canon EF 50mm f2.5 Macro
    Canon EF 100mm f2.8 USM Macro (Pretty far out of my price limit)
    Tamron SP AF 90mm f/2.8 Macro
    Sigma AF28-300 f3.5-6.3 Macro
    Sigma MACRO 105mm F2.8 EX DG
    Any other Lenses that anyone could reccomend. I'm just looking for a decent quality lens, doesn't have to be anything exceptional, just something good enough for me to try my hand at Macro. Budget is a bit of a consideration too.
    Whaddya think?
  2. photofox
    photofox TPF Noob!
    Feb 6, 2008
    14
  3. TCimages
    TCimages TPF Noob!
    Aug 18, 2007
    1,978
    4
    Northern Va
    I would recommend the Canon 100mm Macro, but since its out of your price range, my next pick would be the Sigma 105mm. If I remember right, the 105 does not have internal focus. So the end of it extends toward your subject.
    Lighting is key in a macro setup. Do you have an external flash?
    I don't normally reccomend this over a dedicated macro lens, but since you're just trying it out consider extension tubes.
    http://www.bhphotovideo.com/c/product/375102-REG/Kenko_AEXTUBEDGC_Auto_Extension_Tube_Set.html
  4. doenoe
    doenoe TPF Noob!
    Mar 4, 2005
    4,267
    23
    Hoorn, The Netherlands
    i also have the sigma 105 and am very happy with it. It doesnt have internal focusing, so it moves toward your subject. And like TCImages said, the lighting is very important (i learned this from him too) Makes a world of difference if you use proper lighting
  5. gryphonslair99
    gryphonslair99 Been spending a lot of time on here!
    Sep 9, 2006
    14,446
    2,715
    Wichita, Kansas, USA
    Is this a form a photography you really plan on getting into or are you just trying it out. If you are not sure then IMO you would be better off starting with tubes.
    For $170 you use an existing lens. The tubes have no glass in them so they do not affect the IQ. They can be used with dedicated Macro lenses later on if you really like macro and if you find that you do not care for macro then you can always sell them and recover most of your costs if they are in good shape. They really don't loose much value as they have no optics.
    From the B&H web site:
    This would be a good way to look into macro and decide if you want to continue. If you do, my choice was the Canon 100mm f2.8 Macro lens. Tack sharp and a fine portrait lens to boot.
  6. Dradd
    Dradd TPF Noob!
    Mar 28, 2008
    40
    Cheers for the replys guys.
    I have looked into the Extension Tubes as a possible option, does anyone know what kind of results I could expect with the 18-55mm Kit Lens? Nothing stellar I realise, but having options is a good thing right :D
    I was also mulling over picking up a Nifty Fifty sometime.
  7. TCimages
    TCimages TPF Noob!
    Aug 18, 2007
    1,978
    4
    Northern Va
    It will work fine, but I have to tell you it's tricky. You will only have an acceptable working distance around 50mm and above.
    Here is a shot (not perfect, but you get the idea) with the 18-55 w/ Full set of Extension tubes and Rebel XT. [​IMG]
  8. keith204
    keith204 No longer a newbie, moving up!
    May 20, 2007
    1,643
    Bolivar, MO
    Holy cow. That's gross.
  9. Dradd
    Dradd TPF Noob!
    Mar 28, 2008
    40
    Gross... But cool :D
    Cheers TC.
    When you say "w/ Full set of Extension tubes" What do you mean by Full Set?
    I know Canon do a EF25 and a EF12 extension, do you mean combining the two, or something different.
    Cheers
  10. doenoe
    doenoe TPF Noob!
    Mar 4, 2005
    4,267
    23
    Most of the sets got 3 rings in them. So the full set of extension tubes means that you use all 3 rings on the camera :)
  11. TCimages
    TCimages TPF Noob!
    Aug 18, 2007
    1,978
    4
    Northern Va
    Dann has you covered.
    I wouldn't buy the Canon ones. They are a waste of money considering the quality of air inside them would be the same..:)...They have no glass. Consider the link I posted for ya. Be careful, really cheap ones do not have electrical connections and some do not allow your aperture to work.
    I still recommend a dedicated Macro lens BTW. Dann can show you a link to some wonderful shots taken with the Sigma. Either of these (Canon or Sigma) make a wonderful prime portrait lens. I think the Sigma has infinity focus.
  12. Dradd
    Dradd TPF Noob!
    Mar 28, 2008
    40
    Cheers for the reply's guys.
    I did look at the link you gave me, but I'm tucked all the way down here in NZ, shipping (and import taxes probally) can get a little pricey at times. Need to buy a few things at once to make it worthwhile.
    But I'm sure I'll be able to source something similar locally anyway.
    I would definatly prefer a dedicated Macro lens, but unfortunately sometimes the hobbies have to play second fiddle to the other, more pressing obligations.
    But, Thanks again for the help :D
