Macro Lenses!
Discussion in 'Beyond the Basics' started by cherrypink, Jul 11, 2003.
  1. cherrypink
    cherrypink TPF Noob!
    Jul 7, 2003
    9
    Manchester, England
    Hello - I was thinking of buying a Macro Lens for my Nikon camera, now at the moment I am thinking of the Sigma 50mm or a 105mm lens. All I know is that one is longer than the other, but dose anyone know what the advantages/disadvantages of having a macro lens like this? Does anyone know if these Sigma macros are any good? Thanks! :lol:
  2. dlc
    dlc TPF Noob!
    May 14, 2003
    293
    Indianapolis IN
    The Sigma is a good lens, but you will probably need to focus manually with it. It has a focus hunt problem at the minimum distance, but other macros do too at times depending on lighting and subject.
    The longer the focal length, the more working distance you have between the subject and lens. This is a better arrangement if you are shooting insects. The 100/105mm range is the most common, but there are macros in the 180/200mm range that are excellent but more $$$.
  3. photobug
    photobug TPF Noob!
    Apr 19, 2003
    1,562
    4
    Pasco, WA
    I can't speak specifically to the Sigma lenses, but the longer lens wil give you a bit more room between you and your subject than the shorter lens will.
    If you haven't done any macro work before you might consider getting a macro reversing ring. That allows you to attach 2 lenses together face-to-face to get a macro effect using your existing lenses.
    This is a cost effective method, as the rings cost less than $15.
    hth
    Jim
  4. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Don't expect to find this at your local camera shop. I called every single one in the Phoenix area and they didn't carry it. I ordered it from B & H Photo. If you get it there snag some cheap film, cause shipping will be the same regardless.
    With a 100mm attached to the camera and a 50mm reversed on front, you get 2:1. I was focusing on my keyboard and a single key overfilled the frame.
  5. Westone
    Westone TPF Noob!
    Jul 3, 2003
    19
    Oregon, USA
    Hello
    I use the Nikkor 105mm macro. This keeps me from the subject matter and allows me to use close up diopters sp?? if I wish to go closer than a 1 to 1 magnification. I'm a Nikon user and would suggest you stay with Nikkor if possible. My 2 cents!
    Chuck
  6. MDowdey
    MDowdey Guest
    ive heard "things" about the sigma's too so buyer beware. Jim's idea is excellent though...id try that first.
    md
  7. cherrypink
    Jul 7, 2003
    9
    Manchester, England
    Ooh thanks for all the advice. I read a review today on Macro Lenses in a magazine called Photography Monthly, they highly recommend a lens by Tamron - 90mm. But I think I may check out the adapter thing first if I can find it!
  8. MDowdey
    MDowdey Guest
    good call cherry!
    md
  9. John A
    John A TPF Noob!
    Jun 24, 2003
    40
    Queensland. AUSTRALIA
    I have to go along with Westone's comment, stick with Nikon if the bank balance allows. I use the same lens, Micro Nikkor 105mm 1:1.28 & love it. I have also tried close-up rings but not with anywhere near the same results, but they are not a bad place to start. Beware, macro photography is habit forming. :D
  10. Tsunami1981
    Tsunami1981 TPF Noob!
    Jul 7, 2003
    19
    Minneapolis Minnesota
    I have a Tamron 28-300 Macro Lens and I love it... I would highly recommend it. I paid around the $500 range.
  11. tr0gd0o0r
    tr0gd0o0r TPF Noob!
    Jun 29, 2003
    942
    4
    Shreveport, Louisiana
    I haven't done a whole lot of macro stuff, but i've played around with some cluse up filters. I don't know how far they let you get from your subject, but they're a lot cheaper than a new lense. I haven't looked at the adaptor yet, but the filters will prolly be easier to transport and stuff.
macro lens 1:1.28 focal length
