Macro Question
Discussion in 'Photography Beginners' Forum' started by sj022698, May 23, 2008.
  1. sj022698
    sj022698 TPF Noob!
    Sep 12, 2007
    61
    I can't think of exactly what it is off the top of my head but it's a tamron 70-300 with Macro. Now the macro works good but can only be used when extended almost all the way. So, say I want to take a picture of a plate of food, I have to stand all the way across the room. Thoughts???
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    A lot of lenses say 'macro' but they really aren't what I'd consider to be macro...with 1:1 magnification.
    For a lens like that, you need to be aware of the minimum focus distance, as that is where you will be able to get your most close-up shots.
    If you really want to be able to get close up shots, you might try a true Macro lens, or an extension tube on an existing lens or even a diopter (close up) filter.
  3. doenoe
    doenoe TPF Noob!
    Mar 4, 2005
    4,267
    23
    Hoorn, The Netherlands
    but why do you need a macro lens if you want to take a pic of a plate of food? Or do you want to make a close up of the food item itself?
  4. sj022698
    sj022698 TPF Noob!
    Sep 12, 2007
    61
    Food item itself
  5. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    Well for that you will probably need a macro lens, or for now as suggested get a screw on close up filter.
  6. sj022698
    sj022698 TPF Noob!
    Sep 12, 2007
    61
    Could someone make a recommendation on one please. I'm a big ebay person so that's cool
  7. nicfargo
    nicfargo TPF Noob!
    Jan 4, 2008
    369
    Nebraska
    If you're Canon I'd go with the 100mm 2.8 Macro lens. I think Nikon has something pretty similar. There's also a 50mm but you'd have to be closer to you subject (9'' instead of 18'') in order to get the same magnification. When working with live subjects (insects) that extra 9'' is great. Plus the 100mm 2.8 Macro doubles as a pretty decent portrait lens. Super Sharp!
  8. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    Do you have a budget?
