Macro with a 50mm??
Discussion in 'Photography Beginners' Forum' started by mommy22, Mar 24, 2010.
  1. mommy22
    mommy22 TPF Noob!
    Dec 13, 2009
    191
    Oregon
    Can this be done or do you have to actually have a macro lense?
  2. cnutco
    cnutco No longer a newbie, moving up!
    Aug 31, 2009
    1,566
    51
    NE GA
    You can take nice close ups with the 50, but nothing like with a macro... nothing.
  3. KmH
    Apr 9, 2009
    40,735
    5,587
    Iowa
  4. Ron Evers
    Ron Evers Been spending a lot of time on here!
    Jun 28, 2008
    6,147
    2,017
    In the country just north of Toronto, Canada
    With a cheap set of extension tubes between the camera & your 50mm you can.
    Here is a fig shot that way:
    [​IMG]
  5. mommy22
    mommy22 TPF Noob!
    Dec 13, 2009
    191
    Oregon
    Wow. I'm gonna have to try it out...
  6. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    Ron
    A macro of a fig...go fig ure!
    Sorry, I could not resist :mrgreen:
  7. bgaideski
    bgaideski TPF Noob!
    Feb 7, 2010
    59
    Ann Arbor, MI
  8. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    yeah, with extension tubes you can achieve macro... you just need about the 50mm worth of tubes. Mine were about $67 with contacts so the AF and aperture still work.
  9. Hardrock
    Hardrock TPF Noob!
    Apr 8, 2009
    1,173
    36
    Dallas
    I have a macro lens and it does not autofocus very well at all. I always manual focus when shooting macro.
  10. Ron Evers
    Jun 28, 2008
    6,147
    2,017
    Laf!
    I prefer extension tubes over reversal rings because I do not like the idea of my lens' ass hanging out. ;)
  11. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    4
    Mommy22
    You have 4 basic choices for macro. All work and all have advantages and disadvantages.
    1. Dedicated Macro lens. Advantages: Dedicated Macro lens, no muss no fuss and usually an outstanding portrait lens as well. Disadvantages: usually the most expensive choice.
    2. Reversing ring. Advantages: Cheap and easy. Disadvantages: more potential to do damage to the back end of the lens if you are moving around.
    3. Macro tubes. Advantages: Usually comes in a set of 3 different sizes that can be used individually or together. Great for moving around with for things like bugs etc. Disadvantages: More expensive than reversing ring.
    4. Bellows. Advantages: Wider macro range from 1-1 and closer. Focusing is achieved by adjusting the bellows. Disadvantages: Not really designed to use with moving things like bugs etc. Excellent for static things like watch works etc. Good bellows will run about the same as Macro tubes or more depending on length and features. A tilt/shift bellows is quite costly.
    Easiest way to decided on the method you want to use with your 50mm lens is to know what types of macro you want to do and then choose the best option for that type that you can afford.
  12. mrpink
    mrpink No longer a newbie, moving up!
    Jan 8, 2010
    1,962
    328
    Cincinnati, Ohio
    I'm glad you said that was a fig Ron. My mind was going elsewhere :confused::confused:
    p!nK
