Manual Setting Olympus E510
Discussion in 'Photography Beginners' Forum' started by nieschu, May 24, 2008.
  1. nieschu
    nieschu TPF Noob!
    Apr 15, 2008
    15
    New Haven, CT
    This is probably the most stupid question you have ever heard. But I just tried out the manual function for the first time, after doing some shoots in A, P and S and when I have the camera set on M everything is black. If I try to shoot a picture it is also black. Now, this is my first DSL and maybe thats how it supposed to look like, but I am just very confused. Can someone please help me out? Sorry again for the stupid question.
  2. *Mike*
    *Mike* TPF Noob!
    Mar 26, 2007
    205
    Texas
    When you're taking those shots in Manual, what settings are you using? Is the camera meter telling you that you've got a good exposure? It could be as simple as a dramatically underexposed image...
  3. lockwood81
    lockwood81 TPF Noob!
    Jun 10, 2007
    887
    Daytona Beach
    I shoot an Olympus e-510 and haven't run across that problem, as long as you look at the meter on the back when setting up your shot it should be fine...I agree with *Mike*, maybe it is underexposed (very underexposed)
    I just tried it and to get that kind of underexposure I had to shoot at 1,600 shutter speed with f/22 (or leave my lens cap on)
  4. nieschu
    nieschu TPF Noob!
    Apr 15, 2008
    15
    New Haven, CT
    I honestly have no idea. :( It says in yellow 1/4000 than F22 and something is blinking with -5.0 I tried to change the 1/4000 around and the F22 but it does not change anything on the black image. what else do i have to change? Thank you guys!
  5. bahandi
    bahandi TPF Noob!
    May 2, 2008
    213
    Winnipeg, Manitoba, Canada
    if you are able to... first set the mode to P... see what the camera says the 'best' settings would be for the situation. go back to manual and adjust accordingly.
    1/4000 is a relatively fast shutter speed and f22 is a very small aperture opening. In other words, very little light will hit the 'film' with those settings
  6. lockwood81
    Jun 10, 2007
    887
    Daytona Beach
    1/4000 is as fast as your shutter will go. Since it is yellow that means it can be changed, turn the wheel (the one with no writing on it) clockwise and you will see the number drop.
    F/22 is as closed as your aperture will go. Press and hold down the exposure button, it is just behind the shutter button, this should turn the aperture yellow and can be changed with the same wheel, turning it clockwise.
    PM me anytime with any questions you might have.
    Have fun shooting.
  7. nieschu
    nieschu TPF Noob!
    Apr 15, 2008
    15
    New Haven, CT
    thank you so much for your kind reply! I actually figured it out just before I read your answer. So thank you very much. I realy need to learn more about all that stuff to understand what it means. Thank you so much agian for taking the time to reply!
    Actually I have one more question. I was shooting an event yesterday and two times my camera just froze. It didnt do anything anymore, I tried to shut it off and then back on, then it recovered but it took quite a while and I lost some nice picture opportunities. Then a little later I had to switch the memory card and the camera was fine until a little while later when it suddenly said it cant recognize the memory card. Then it went away and after an hour it came back on, ruining the "cutting of the cake" moment. I just recently purchased that camera so I am a little upset, did that ever happen to someone?
  8. elemental
    elemental TPF Noob!
    Feb 6, 2008
    646
    This has never happened to me, but if it were to on a brand new camera I would be on my way back to the store. That should not happen on a just-recently-purchased camera, and you shouldn't put up with it.
  9. djrichie28
    djrichie28 TPF Noob!
    Jan 24, 2008
    264
    7
    Waterloo, ON
    The "-5" is your meter telling you that the exposure settings are gonna give you an underexposed image. (Black picture) Sounds like your meter works great.
    I used to shoot with an E-500 and I am guessing that they are going to be somewhat similar as far as controls go. In manual mode, the wheel on the top near the back is going to adjust the shutter, and if you hold the button that shows +/- on it while rotating the wheel, it should adjust the aperture. That is of course if it operates similar to the E-500.
    You want that yellow -5 to get to 0. -5 means under exposed, so you need to expose your sensor more, by lengthening your shutter time and/or opening the aperture.
    Hope that helps a bit. Good luck
  10. lockwood81
    Jun 10, 2007
    887
    Daytona Beach
    I've never had the happen or heard of it happening and it shouldn't happen.
  11. Atreus
    Atreus TPF Noob!
    Nov 13, 2007
    140
    lens cap is off right? :p
    glad you got it worked out.
  12. djrichie28
    Jan 24, 2008
    264
    7
    Waterloo, ON
    Have you formatted the card using the camera?
how to change f stop evolt 510
olympus e-510 aperture
olympus e510 camera quick guide settings
