Manual white balance in mixed lighting conditions
Discussion in 'Photography Beginners' Forum' started by Yoshi, Jun 3, 2008.
  1. Yoshi
    Yoshi TPF Noob!
    Jun 3, 2008
    Hi, I have a few questions on white balance and lens flare. Can someone please help me out.
    -When you are in mixed lighting conditions and you want to have the real colours everywhere, how do you manually white balance then? And where should you place the white paper? I'm talking here about the situations where you can't put CTB or CTO to adjust the colours.
    -Also when a light is much brighter than it is in reality but there are no rays or little circles across the image, is this also called lens flare? And how do you do to not have this? For example, your are filming the sun and it looks much brighter than it is in reality.
    Thanks for your help.
    Yoshi
  2. djrichie28
    djrichie28 TPF Noob!
    Jan 24, 2008
    264
    7
    Waterloo, ON
    Place your paper anywhere under the mixed light to get the reading. An alternative would be to shoot in RAW which gives you the flexibility to set your white balance after in post processing.
  3. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
  4. bahandi
    bahandi TPF Noob!
    May 2, 2008
    213
    Winnipeg, Manitoba, Canada
    is that a filter, of sorts?
    and i believe lens flare is those little circles of light that gets copied onto the image
  5. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Wasn't this posted and answered to in another section already today?
    Just wondering WHY post the same question from the same person in 2 different ways? :confused:
  6. JIP
    Aug 29, 2006
    3,019
    Pittsburgh PA
    of sorts you put it on your lens to set the white balance for a scene and then take it off and shoot.
  7. tirediron
    Jul 8, 2005
    41,108
    12,494
    Victoria, BC
    -Shoot in RAW
    -Do calibration exposures of both a white and neutral gray card in several different areas
    -Adjust the WB in PP using those calibration points
