Mars
Discussion in 'Landscape & Cityscape' started by Jeff Canes, Jan 25, 2009.
  1. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    [​IMG]
  2. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    It's a little soft, Was that intentional?
  3. Jeff Canes
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    No it was not intentional. But it could have be a resoled of the equipment, film or workflow.
    The film is 120 EIR, this was the first I have used it in that format. I need to check the negatives for sharpness.
    Camera: Rolleiflex Xenotar 75mm F3.5 Filter: #2 Bayonet to 52mm filter adapter & #13 yellow. I think the filter adapter and filter add some vignette effect and likely soften the outer edges. This was the first time I’ve used a filter on this camera and don’t ever recall see any vignette before. I’m not sure about the sharpness of the camera itself
    The Scanner is an older Epson flatbed and the weakest link in my workflow; I’ve wanted to replace it for sometime. It definitely affected the sharpness.
  4. TamiyaGuy
    TamiyaGuy No longer a newbie, moving up!
    Jun 25, 2007
    1,078
    Chelmsford, UK
    Although, as Battou said, it is fairly soft, I like it. The depth of field, in my opinion, is near perfect. You can make out minor details in the background, but my attention is centred on the plant in the middle (or tree, I'm not quite sure now). My only suggestion would have been to somehow get rid of the rocks in the foreground, they don't do too much in my opinion.
  5. Battou
    May 10, 2007
    7,997
    26
    When working with Film and shooting with any notion of digital display, your scanner is just as important as the camera it self. When I initially looked at the photo I was completely unable to find a sharp spot and assumed that this was not a case of missfocus but was still unsure of the intentions....if that makes any sence. I'd say replace that beastie as soon as possible, but for now try cleaning the glass with a squeagy(SP?) because residue from cleaning solutions will make any shortcommings in the glass that much worse.
  6. abraxas
    abraxas No longer a newbie, moving up!
    Aug 15, 2006
    10,417
    9
    Jeff,
    What a cool effect-
    What is the "E", in EIR?
  7. Jeff Canes
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    the E stands for Ektachchrome, EIR was discontinued last year, I actually used Aerochrome 1443, that film is basically the same as the discontinued EIR
