Max sync speed
Discussion in 'Photography Beginners' Forum' started by Jus7 A Phas3, Feb 26, 2008.
  1. Jus7 A Phas3
    Jus7 A Phas3 TPF Noob!
    Sep 26, 2007
    236
    CA
    Im thinking about getting skyports because i dont want to spend tons of mone on PW's. Im going to be using them off camrea all the time, most likely SB 24's or 26's. Skateboard photography is my think so i will be shooting alot of that which will require a fast shutter speed like 500 or higher which i know my D80's max sync speed isnt that fast. I am confused will i only be able to shoot at what my camreas max sync speed is at or will i be able to shoot faster?
  2. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    The standard sync speed is 1/200s which stinks, but you can crank it up even higher if you're using Nikon Creative Lighting System compatible flashes (SB-600 or SB-800) via the high speed sync mode. It'll let you work at flash sync speeds of 1/500s or even faster, but it's enormously wasteful of flash power. This is one of several reasons why I have my D40. It has a real 1/500s flash sync which makes freezing daylight action without harsh shadows on people's faces a whole ton easier. The D50 and D70 also had 1/500s flash sync speeds.
  3. Jus7 A Phas3
    Sep 26, 2007
    236
    CA
    Thanks, so does that mean that unless i get SB 800's or 600's i cant sync my off camrea flash up to 500 I can only shoot at 200 or my camreas flash sync speed theres no way to have it go faster like maybe 1000 even with the SB's?
  4. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,696
    64
    Missouri
    Yes, that's what it means.
    Having said that, there are two options you might consider. One is getting a D40 or a used D70 which have a flash sync of 1/500th of a second.
    You can use FP, but keep in mind (and no, I am not a math guy so I can't give a good explanation of this) that the faster you sync your flashes with FP, the less light they put out proportionally (I use the word proportionally to satisfy one particular user here ;) ). If you are shooting close up, this is no big deal, but if you are giving your flash guns a workout by using the longer ends of their range, then the guide number reduction is something to pay attention to (i.e. you MAY need more flashguns).
    Consumer grade cameras cannot be all things to all people.
    Personally, if you need a high speed flash sync, I would just pick up a cheap D40 and run with it.
  5. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    Another option would be to shoot when it's dark. The burst of flash is very very fast/short and will freeze the action, even if your shutter speed is long.
    Yet another option is to forget about flash and just shoot with as fast a shutter as the light will allow.
  6. Shibby!
    Shibby! TPF Noob!
    Oct 10, 2007
    283
    Calgary, Ab. Canada
    Another thing to remember (from what I've read) is that a more powerful flash (1/1) has a longer durration so it opens the door to motion blur, where as 1/4 and 1/2 have a lot faster "flash" time.
    Goes against what most people think, but I know I am going to try it when I start shooting my action sports again. Shoot with a lower Fstop and lower the flash power.
  7. sabbath999
    Apr 11, 2007
    2,696
    64
    Missouri
    Keeping in mind that "longer" in flash terms is still EXTREMELY short in duration...
  8. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    Yes. A very long electronic flash duration (excluding FP mode) is approximately a millisecond (1/1000 second).
  9. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    Another option is to just try what you have. The trick is to get the skate boarder just when he/she comes to a stop and is about to reverse course. I believe you have 2nd curtain sync, also, which may make you want to try even slower shutter speeds, maybe even down to 1/30 th of a sec to get that trailing blur behind the sharp subject. Experiment! It’s digital, so shoot often.
  10. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    Yeah, rear-curtain sync flash. Not exactly skateboarding, but I took this at 1/30s and tried to track as best I could. I didn't think to use rear-curtain sync flash, but it probably would have helped. I was sorta shooting in stealth mode anyways.
    [​IMG]
  11. Jus7 A Phas3
    Sep 26, 2007
    236
    CA
    So it looks like unless i spend 300 or so dollers on Sb800's i wont be able to shoot any skateboard photography with flash. That sucks, well it looks like im gonna save my money up for a fisheye then. Thanks guys
  12. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    You don't need an SB-800 for most things. A 600 at about half the price is just fine. And like somebody else mentioned above, with practice and if you time your shot just right, you should still be able to freeze shots at only 1/200s based on their trajectory. Just get creative. Try to get a skateboarder that's frozen, but with a little motion blur in the background if you track their motion perfectly. These photos can look fantastic.
rear curtain flash
rear curtain flash skater
rear sync flash
shutter speed for slateboarding
shutter speeds skateboarding
skate photography high speed sync
skateboarding high sync speed
sync speed for skateboarding
sync speed for skating
