medium, large format?
Discussion in 'Photography Beginners' Forum' started by julie32, Jul 8, 2007.
  1. julie32
    julie32 TPF Noob!
    Jun 25, 2007
    354
    New York City
    So no one liked my "eos viewer utility" question. I think it's the only one on here with "0" replies!!
    Can someone please explain to me what medium vs. large format is? Or even "full frame." I have the 20D and people are telling me to get the 5D due to the "full frame capacities." Are they talking about how wide the photo is? I'm so confused.
    Thank you in advance,
    Jules
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    a full frame digital sensor gives one the same image size as a 35mm. Most digital dslr have a sensor that is smaller, an APS ratio.
    Medium format cameras , covers a format size of 6x6, 6x7, 6x9' Large format sizes begin at 4x5 and goes upward from there.
    With regard to formats size, the larger the format the more information that is captured; more infomration translates into more detail, tonal range; each giving a specific character to the print.
  3. aMac
    aMac TPF Noob!
    Jul 7, 2007
    35
    UK
    The important thing about cameras being "full frame" in the digital SLR world is how it affects the lenses you use.
    Most DSLRs have a sensor that is smaller than normal 35mm film. What this means in practice is that the image projected onto the back of the camera is cropped slightly, making the image seem to be more zoomed in than you'd expect for that length lens on a camera with a full framed sensor or film.
    Typically the size difference between most DSLRs and a full frame is about 1.6 times the size. A 100mm lens on a full frame camera gives just that; 100mm equivalent pictures, but a 100mm lens on a typical DSLR will make a photo equivalent to have being shot on a 160mm lens on a full-frame camera. A 50mm lens turns into an 80mm lens on most DSLRs.
    This isn't normally a problem until you want to take really wide shots, when the cropping makes those wide angle lenses just not quite as wide angle as they should be!
  4. jstuedle
    jstuedle No longer a newbie, moving up!
    Jun 30, 2005
    4,889
    14
    S.E. Indiana
    Just to clarify, the med format listed above are metric in centimeters. 6X6 is also called 2 1/4" square. the large formats are in inches, 4"X5", 8"X10" and so on. Sometimes the numbers game can be confusing.
  5. Mike_E
    Jan 26, 2007
    5,327
    266
    First, are you happy with your photos? If not and you have exhausted the capabilities of your camera then by all means start shopping around.
    If you are happy or still have plenty of head room, then understand that there are photographers that press the shutter button halfway down and check the exposure and compose their shot and fiddle with the aperture and so forth.
    And then there are photographers that push the shutter button all the way down and and will even (Oh my word!) make a print using whatever camera they happen to have in their hands.
    Decide which kind of photographer you want to be and go hang with them and be happy that the other half will never have any use for you!
    enjoy
    mike
  6. julie32
    julie32 TPF Noob!
    Jun 25, 2007
    354
    New York City
    thank you so much amac. That info is just what I needed. Your bunny is so cute, btw.
  7. julie32
    julie32 TPF Noob!
    Jun 25, 2007
    354
    New York City
    Mike
    your reply totally made me smile.
    thanks for it.
  8. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    "Full frame" can also refer to using the entire image area on the film to make prints. Most labs use slightly less (96% to 98%) of the full image area when making normal machine prints.
  9. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,700
    68
    Missouri
    BTW generally most people refer to medium & large format cameras that are film versions... there are medium format digital cameras, but they are over $10K... quite a bit over, in fact.
