Megapixels and Actual Sharpness vs. Percieved sharpness
Discussion in 'Photography Equipment & Products' started by Antithesis, Sep 9, 2009.
  1. Antithesis
    Antithesis No longer a newbie, moving up!
    Aug 24, 2007
    1,340
    16
    Caribbean
    So I just finished reading a Thom Hogan article on the D2x randomly, and he states that a higher MP count (well, 12 isn't that high anymore) will lower the perceived sharpness and will make it more difficult to achieve truly sharp images.
    So, with that said, does a lower MP camera have images that appear sharper when viewed as a full image? Or is this occurrence only going to happen at pixel depth viewing? For example, if you have a 12mp sensor and a 6mp sensor, shot through the same lens, would the 6mp look sharper than the 12mp, when viewed at the same size on your monitor?
  2. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    202
    Canada
    No, he is wrong. I have noticed sharpness differences related to 5 meg. vs. 8 meg. vs. 14.2 meg. vs 21 meg. when used on the same or similar scenes.
    skieur
  3. sween
    sween TPF Noob!
    Dec 25, 2008
    65
    This probably means little for those who'll take a totally tekkie approach, but I read a paper on pixels and sharpness not long ago which stated that, once you hit 10 MP, the next level at which the human eye can detect any real difference is at roughly 18 MP. True? Don't know. However, I don't doubt it.
    It's just a continuation of the never-ending sharpness debates during the film days and which lenses delivered, which did not, etc. My opinion then, as it is now, is that when someone looks at my work, I don't hand them a loupe at the door before they step into my home where it's upon the walls.
    If it looks sharp, it is sharp.
    That being said, shall we commence to discussing what lenses deliver the best bokeh?
  4. KmH
    Apr 9, 2009
    39,011
    5,234
    Iowa
    That's easy, the ones with the most, and roundest, aperture blades. The Nikon 85mm f/1.4 Cream Machine comes to mind as a fine example.
  5. bhop
    bhop No longer a newbie, moving up!
    Dec 10, 2007
    2,211
    236
    Los Angeles
    My d70 pics look sharper from the camera on screen than my d200 pics. 6.1 vs 10.2mp
  6. Sue Bruce
    Sue Bruce TPF Noob!
    Apr 22, 2008
    39
    15 miles NW of Boston, MA
    All I can say is that I usually shoot with a 40d ... and recently rented a 5d mkII ... and I was blown away by the sharpness!!
    So much so .. that I've been crazily saving for one. Of course, now that the 7d has been announced, I have no idea if I'll end up with one ... but the difference between 21 and 10mp was amazing to me ...
    Sue
    Sue Bruce Photography
  7. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    D70 was probably one of the sharpest Nikon bodies for images right out of the camera. Nikon got a lot of complaints about the D100 being too soft, so they put a much gentler anti-aliasing filter in on the D70.
    People then, of course, complained about moire patterns because the D70 was too sharp. :lol: So the D200 is "soft" again, as it should be.
  8. Antithesis
    Aug 24, 2007
    1,340
    16
    Caribbean
    Can you explain? Are you saying more MP equals sharpness, or vice-versa?
  9. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    Same with my D700, at the per-pixel level, it's softer.
    I loved shooting RAW with my D70 and in ACR or C1, images were SHARP SHARP SHARP!!!
    I've thought about removing the AA filter on the 700 so it would be sharp like the D70 is, but concluded that it would be a waste of time and money.
  10. MrLogic
    MrLogic TPF Noob!
    Mar 27, 2008
    423
    Rotterdam, Netherlands
    How did you come to that conclusion? I like the D700/D3 look just fine, especially when used with the 85 f/1.4, or very sharp lenses such as the Sigma macros, or the 14-24mm f/2.8 ...but it is significantly softer at the pixel level than the 24.5 megapixel Nikon 3DX (from the tests I saw online & in magazines)
    However, if what Thom Hogan said is true (I don't think it is), the 3DX would have a lower "perceived sharpness".
  11. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    I don't see any technical basis for his assumption other than he has a crap lens and when cranking up the megapixels the faults of his lens are showing. Honestly try tell 45mpx medium format shooters that their images aren't as sharp as bog standard Aps-C, you'll be laughed out of the room.
    The point at where this madness stops is that when lenses are sharp enough to be truly diffraction limited, and the sensor has high enough resolution to resolve this level. At this point anything more megapixel wise just reduces sharpness and you may as well just upsample in photoshop.
  12. skieur
    skieur TPF Noob!
    May 14, 2007
    5,076
    202
    Canada
    To put it a little differently, with a 5 meg camera flower petals may not look soft but with 10 meg camera you can see the surface texture of the petal. With a 14 or 21 meg, you can see sharp edges and detail in distance shots that blend together using a 5 or 8 meg.
    skieur
megapixel sharpness
megapixel vs sharpness
megapixels and sharpness
megapixels sharpness
megapixels vs true resolution
megpixel shARPNESS ON monitor
more megapixels more sharpening
resolution vs sharpness
sharpness vs resolution
true resolution vs megapixels
