Merry-Go-Round - CC
Discussion in 'Photography Beginners' Forum' started by SwissJ, May 11, 2010.
  1. SwissJ
    SwissJ TPF Noob!
    Mar 29, 2010
    243
    Brooklyn, NY
    Practicing my panning motion blur technique.
    As always, please C&C! Thanks.
    [​IMG]
  2. MDWine
    MDWine TPF Noob!
    Jan 4, 2010
    57
    Manassas Park, Virginia
    Looks good from here.
    I especially like the vibrant colors, and the lights in the top left.
  3. flea77
    flea77 No longer a newbie, moving up!
    Feb 6, 2009
    593
    34
    Huntsville, TX
    You're getting there. The speed of pan doesn't look quite right, may be a little off, or maybe a little too long exposure which caused the horse to move towards or away from you a little too much to keep it sharp. Also, I would at least crop it so that it is level.
    Allan
  4. SwissJ
    SwissJ TPF Noob!
    Mar 29, 2010
    243
    Brooklyn, NY
    Thanks to both of you.
    I think it looks odd cause the hind legs are in motion while the head is relatively frozen.
    I actually cropped this at the angle so that it would be more dynamic and lively, and to give the horse more of a take-off effect. I'll try some other crops and see how they work out.
  5. creisinger
    creisinger TPF Noob!
    Oct 19, 2009
    470
    Miami
    I think it's quite challenging to try motion blur on an object that moved in a circular motion to and away from the camera all the time.
    That may be an explanation why the rear of the pony is not as sharp as the front.
    I'm not too excited about the "tiltedness". I'd level the image before posting.
    Also, the two horses in the front are blown out. Lower your ISO to 100 or lower if you can to get the necessary exposure time for the pan (also a higher aperture would do the trick).
  6. myfotoguy
    myfotoguy TPF Noob!
    Feb 15, 2010
    855
    Minneapolis, MN, USA
    I agree with creisinger, panning this type of motion can be tough, but you did good.
    I again agree with creisinger about the exposure, the horses are a bit overexposed. That is common in panning, because of how the camera is metering, especially if you are using flash (by the way, rear sync works nice for panning), but again, in my experience any flash in panning increases your chance for overexposure depending on flash mode and how it meters. Just something to be aware of. I use negative exposure compensation, or sometimes exposure lock for panning children swinging.
    Article on panning should it prove helpful to anyone.
  7. SwissJ
    SwissJ TPF Noob!
    Mar 29, 2010
    243
    Brooklyn, NY
    Great info. Many thanks.
    I'm guilty of overexposing the horses extra in post. If anyone cares to see, here is the original with the camera's neutral picture style--toned down and not tilted. Some detail in the center horse is still visible. Not the best of compositions, but it is what it is.
    [​IMG]
  8. SwissJ
    SwissJ TPF Noob!
    Mar 29, 2010
    243
    Brooklyn, NY
    :thumbup:
