metering mode
Discussion in 'Beyond the Basics' started by shingfan, Jan 28, 2007.
  1. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    can you pros help me understand the metering modes....and how does it pratically work and when should i use the different mode?.....when would be a good time to use matrix or spot?....i have a nikon D80
  2. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    I use matrix 90% of the time on my D70s. You'd want to use spot metering for possibly high contrast subjects. for example, if you took a picture of a person in front of a bright window and didn't want the person to come out black, you'd use spot metering and put your selected AF point on the person so the camera would expose for that instead of the window light.
  3. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    I use spot, or center weighted average for everything. I like to use the zone system, and therefore I like to know the exposure of different parts of my scene, selectively.
    Matrix metering divides the field of view into 5 zones, 4 corners, and a center. A reading is taken of each zone, and each zone is averaged. Then those averages are added together and averaged to come up with your exposure. If you have a tricky lighting scenario, it can sometimes fool this type of metering.
    Spot metering is usually tied to the center focus point, and measures the exposure value of a very tiny part of the frame, usually less than 10 degrees.
  4. shingfan
    shingfan TPF Noob!
    Dec 29, 2006
    569
    Toroto, ON
    for spot metering....is it measuring the "focus point"....or only the "centre focus point"?.....
    also...matt...you mention that you use the zone system to know the exposure of different parts selectively....are you also able to expose different zone selectively on a single image?....or need to combine images with different exposure?...HDR?....if you dont mind...i like to learn a bit about making practical use of the metering system
  5. Digital Matt
    Jan 30, 2004
    5,346
    66
    Santa Barbara, CA
    Usually, spot metering in TTL metering is linked to the center focus point. You'll have to check your manual.
    As for the zone system, you have to know the dynamic range of your medium. Most digital sensors can safely record around 5-7 stops. You should read up on the zone system via a google search.
  6. hazzayoungn
    hazzayoungn TPF Noob!
    Dec 20, 2006
    110
    Seattle
