Precisely. Meters provide recommendations, not answers. Photographic experience determines whether that recommendation is correct for the subject. An obvious example is a snow covered landscape. Since meters attempt to reduce the subject to a medium gray, the snow will be gray (underexposed) if you follow the meter recommendation blindly. Snow scenes usuallly need 1 1/2 to 2 stops more exposure to render things accurately.The camera DOES meter in full manual mode... it just doesn't set the exposure for you. Basically it offers you "advice" on whether it thinks your current exposure settings are going to result a correct exposure vs. an over-exposure or under-exposure and it's up to you to adjust settings.
It may help you while you become more familiar with your camera to use aperture priority mode (A or Av) and use +/- exposure compensation to alter the shutter speeds if needed. This way you can decide on how much depth (depth of field) you'd like to have in sharp focus, and the camera will try to select the best shutter speed. But sometimes, for example when you're without enough available light, you might choose to intentionally underexpose a bit (negative "-" compensation), so you can still get a shot without excessive camera shake.
Other times, the camera may be tricked by some situations into under/over exposing, so in this case you want to override the cameras metering with +/- compensation.
You may already be at max iso. You may be making a b&w and be happy with some luminance noise. Why get all pompous about it? I noticed you do this often, to the detriment of the forum.
