Metering?
Discussion in 'Beyond the Basics' started by Harpua, Feb 12, 2006.
  1. Harpua
    Harpua TPF Noob!
    Jan 26, 2006
    119
    West of Boston
    Can someone explain the basics of metering to me? I know mt D70s has a meter, but I do not know what I am looking at or what I am supposed to do with the meter.
  2. DestinDave
    DestinDave Master of Non Sequitur
    Jan 29, 2006
    480
    Not where I thought I'd end up
    All light meters, whether handheld or on-board, are designed to examine a scene and calculate the amount of light needed to produce an 18% gray image. This is a magical number devised years ago to render (in a perfect situation) all the tones from pure white to absolute black. Same for color except colors are perceived as grayscale. Problem is there is no perfect situation. If you are looking at a scene with more white or highlights then the meter will adjust the settings to lower the light to reduce the overall scene to 18% gray, thereby darkening the shadows and losing detail in those areas. If you are shooting a particularly dark scene with a few highlights, the meter will suggest more light/slower speed to increase the detail in the shadows but this may blow out the highlight areas. A spot meter allows you to meter individual areas of a scene. Often, I will meter on different areas of a scene, and select a manual setting in between the high and low. If in doubt, I bracket my shots. Hope this helps some...
    Dave
    P.S. Pick up an 18% gray card at a photo lab or order one online. Carry a piece of it with you on shoots. Using the same incident light as your subject, meter the gray card, and use that setting. Perfect exposure every time.
  3. Harpua
    Harpua TPF Noob!
    Jan 26, 2006
    119
    West of Boston
    Thanks DestinDave.
    So what am I supposed to be looking at when I look at the meter, and what I am I supposed to do? I am guessing it has something to do with f stops, but I am seriously a novice at this stuff so I have zero clue. Thanks!
  4. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
  5. Harpua
    Harpua TPF Noob!
    Jan 26, 2006
    119
    West of Boston
    Thanks Rob. I have some reading to do :)
