Metz 45 CT 5 NC with Canon SLR?
Discussion in 'Photography Equipment & Products' started by Alex_B, Nov 26, 2006.
  1. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    Hi, time for me to aks a question in here myself ;)
    Does anyone have experience with the Metz 45 CT 5 flash with todays Canon (D)SLRs?
    I've got a Canon EOS 100 and an EOS 5 D ... is there ANY chance to use this flash?
    I got this flash for free today.
    Cheers!
  2. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    hmm, looks like nobody has experience with that flash?
  3. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    hmmm ... ok, i give up on this one ;)
  4. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    From this site
    It says that the Metz 45 CT 5 is rated (measured by user) at 14.8 volts for trigger voltage.
    I'm guessing that the 5D is rated for 200 or 250 volts (like my 20D)...but your EOS 100 may only be rated at 6V volts...however, the ISO standard for cameras is 24 volts...so 14.8 volts is listed as 'your call'.
  5. Patrice
    Patrice No longer a newbie, moving up!
    Dec 6, 2006
    2,392
    381
    Campbellton, New Brunswick, Canada
    I have one of those, as well as a CL4. Have to use them as manual flashes with any body that uses iTTL (Nikon). I was able to get a module for the F4s for the CL4 so I get full flash functionality with that camera. I don't know about Canon though. The CL4 and CT5 will fire all day and recyle in 2.5 seconds using a Quantum battery.
  6. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    thanks for the link and the feedback!
    I own one of thesde flashes now, and I will have to decide if I puit any effort into it to get it working with my Canon 5D or my 100 ... or if I sell it via Ebay .. but it is a nice flash technically.
  7. MTMTexas
    MTMTexas TPF Noob!
    Dec 13, 2006
    7
    Deepinheata North Texas
    I believe this unit used the SCA-300.
    I think Bogen might distribute this line nowadays (?)
    They should have data on intercangabilty and usability.
    Now, Logically (an when does logic ever apply?) it would seem that if any "advanced" featured flash worked with "advanced" feature camera it "should" provide those features with the digital camera.
    I would assume that, say a SB24 would work just fine with a D-50 ot D-70 Nikon.
    I don't know about Canon..
    Good Luck..
    Ciao,
    Tom
  8. markinuk
    markinuk TPF Noob!
    Mar 3, 2011
    Um... No. To start with the CT5 used the SCA500 adaptor - this was discontinued and hard to find. You can still use the CT5 unit with a Canon digital camera provided that you can reduce the trigger voltage to a safe level. Wein Safesync is about the only way to go. This will sit on the hotshoe and allow you to plug in via PC cord.
    You will not get any information from the flash unit going through to the camera, so no flash ready light in the viewfinder, no TTL metering. You'll be operating on pretty much a manual basis, or at best shutter priority. If the latter, you need to set the flash unit to the distance from camera to subject and rely on the camera's metering for light. You may be able to get rear curtain/front curtain sync, but no red eye. I tend to use mine as a slave unit triggered by an optical slave from the inboard flash. Provides a nice amount of light when bounced via a brolly.
