Mid-range zoom lens= Nikkor 70-300?
Discussion in 'Photography Equipment & Products' started by Nero-O9, Feb 3, 2009.
  1. Nero-O9
    Nero-O9 TPF Noob!
    Mar 19, 2008
    8
    Camera and lens. Nikon D90 kit lens 15-105mm, extra lens nikkor lens 70-300mm.
    This is the bag I bought http://products.lowepro.com/product/SlingShot-100-AW,2034,4.htm its to small. In fact the the big lens is all most longer then the bag. This is the one Im thinking about getting http://products.lowepro.com/product/SlingShot-200-AW,2035,4.htm. But not sure if its going to fit the body+ the long lens.
    This one http://products.lowepro.com/product/SlingShot-300-AW,2036,4.htm says it will fit the body with attached lens but I don't need to space for 5-6 extra lenses.
  2. shivaswrath
    shivaswrath TPF Noob!
    Sep 18, 2007
    302
    Norwalk, CT
    the 70-300 isn't that large, it's about 5.5 inches or so (when I last used it). . .GREAT lens, can be used FX/DX. . .not sure if your question is about the lens or bags you linked out, because a D90 + Kit Lens +70-300 WILL fit. . .I wouldn't go larger than an 100AW. . .have you tried these bags out either?
    I went to a camera store and tried a number out, and ended up on the toploader 75:
    Lowepro - Toploader 75 AW
    The beauty about it is you can add these lowepro accessory cases Lowepro - Lens Cases
    to the bag, so great for future expandibility!
  3. Nero-O9
    Nero-O9 TPF Noob!
    Mar 19, 2008
    8
    That maybe why your the only one to reply it was a rush post. its about the bags. ya the 70-300 didn't fit in the bag (100aw). I didn't have the D90 at the time it was still being shipped in.
    As for camera stores here I don't know of any. But then I haven't looked ether.
    Id like to get a slingbag.
    Ill ether order one try the send it back or something. All the bags Ive looked at show a 18-200mm lens one the D90. In not sure how much longer the 70-300mm is?
  4. shivaswrath
    Sep 18, 2007
    302
    Norwalk, CT
  5. shivaswrath
    Sep 18, 2007
    302
    Norwalk, CT
    i'm confused here, the 100 AW states the following:
    So, umm, how are you having problems fitting a mid-size dslr like the D90 + 2 lenses?
    I'd order the 200AW and I guess size it out, but it should all fit. . .might want to try the tenba sling as well, only $99 and seems pretty nice:
    http://www.tenba.com/products/Shootout-Medium-Sling-Bag.aspx
  6. Nero-O9
    Nero-O9 TPF Noob!
    Mar 19, 2008
    8
    Ya ill just try the 200AW. If that doesnt work ill get the tenba bag. Thanks for the help.
  7. TUX424
    TUX424 TPF Noob!
    Aug 17, 2008
    447
    St. Louis, MO
    I've got the Lowe-pro Slingshot 200AW and it has a good amount of space, well enough for what i need. But ill report back when i've got is loaded with some new lens that i see in my future (Tokina 11-16, 85 1.8, 55-200 VR) But i know that they Slingshot 200AW can be had for about $65 New on ebay.com
