Minor Lens Repair Issue
Discussion in 'Beyond the Basics' started by JSD, Aug 9, 2009.
  1. JSD
    JSD TPF Noob!
    Aug 9, 2009
    138
    Colorado
    I have a question for anyone who might be knowledgable about lens repair. I have a Nikon 80-200 zoom who's rubber zoom grip is loose. Especially when hot out I need to grip excessively hard or the rubber simply slips. Can I glue this with a few dabs of rubber cement? Or should I take it in to a pro repair shop?
    Thank you,
    JSD
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Depends on how much the lens is worth to you. You probably could just dab on a bit of glue, but I would take it to a certified repair centre and get a guarantee with the repairs.
  3. JSD
    JSD TPF Noob!
    Aug 9, 2009
    138
    Colorado
    Thanks for the reply, I will check into it.
    JSD
  4. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    I used DS tape once but like an idiot I took it out in sub zero weather before it was ready and the grip contracted and screwed the whole shooting match.
    I have in the past used the spray adheasive in the craft section in Wall-Mart/Kmart to re apply a lens grip, It worked well enough to say it worked. The grip I reapplied was not perfict so the results are not perfect but I am pleased with it considering. The Spray adheasive has much more give than the DS tape, I would suggest the spray if you are in a place with major seasonal variation.
  5. epatsellis
    epatsellis TPF Noob!
    Apr 15, 2008
    537
    22
    I have a roll of 3m VHB tape just for little things like this. I dare say having a pro fix it would probably cost less than the roll of tape though. (I had it left over from a job we did a few years ago)
    erie
  6. JSD
    JSD TPF Noob!
    Aug 9, 2009
    138
    Colorado
    Thanks for the help folks, I appreciate it.
    JSD
  7. Battou
    May 10, 2007
    7,997
    26
    I did type up a how too for the DS tape fix if you want it....Just don't let it go from warm to cold in a hurry....
    I could alsi explain the slight variation to the other methoed too if you want
  8. JSD
    JSD TPF Noob!
    Aug 9, 2009
    138
    Colorado
    Thank you, I would appreciate whatever info you could pass along. The nearest Nikon shop is a half day drive away so I hope to deal with this myself.
    JSD
  9. Battou
    May 10, 2007
    7,997
    26
    Forgive my spelling...I am a horrid speller
    http://www.thephotoforum.com/forum/collectors-corner/157184-lens-grip-repair.html
    Now there is a bit of variation if you choose to use the sprey adheisive. If you opt to do the sprey adheisive step three is simply taking the grip and spreying it with the adheisive as opposed to applying to the barrel. and the rest is pretty much the same.
    Also keep in mind, with this repair there is a chance for separation if the grip gets really cold but it does not effect the performance.
  10. JSD
    JSD TPF Noob!
    Aug 9, 2009
    138
    Colorado
    Thanks Battou, but I think I like the slip-a-little-glue- under-the-grip method better. I dont want to cut the grip. I appreciate your effort in helping me out.
    JSD
  11. dpolston
    dpolston TPF Noob!
    Apr 8, 2007
    949
    Norfolk, VA.
    I know this is an old post but I searched it and here's what happened. I had the same problem with my Nikon 70-200 2.8. I notice that when I shoot this lens I tend to roll my zoom with my left hands middle finger. So I need it to grip.
    This morning I brought it to work and fixed it. The DIY fix process was; I flipped the rubber grip that was completely loose inside out. I never removed the grip from the lens, I just turned it over to the barrel closer to the front of the lens. Next, I used painters tape and construction paper to tape off the areas on either side of the inside out grip (note: I did one end and slid the grip down a little over the tape and then taped off the other side. This way I could slide the grip over each taped end a bit before the next step). Next, I used a fairly aggressive spray adhesive (Its a 3M called '77') and evenly sprayed one light coat onto the backside [inside out side] of the grip. Next, Remove all the tape and flip the grip right side out onto the lens barrel where it belonged. I ended up 'working' the grip back into place with my fingers for the next couple minuted to get it lined up. The last thing I did (USE CAUTION) was to take a heat gun and gently warm up the grip (mine had loosened because it was streched as well. The heat shrank it a little to fit better). ONLY do the heat gun thing if you are sure you can handle it. In my profession or 'day job', I build sets and scenery that you see on tv (like the sit-coms and news sutdios) so I work with these kinds of things all the time. So be careful and this should only take 10 entire minutes and save you service cost plus down time!
    Hope this helps!
  12. michaelleggero
    michaelleggero TPF Noob!
    Sep 13, 2010
    210
    Carthage, NY
    this is a common problem. it's really easy to fix but you need the right kind of tape. go to somewhere that makes trophies. ask them for a few feet of their double stick tape.. it's very very thin and super sticky. that's what you want trophy double stick tape... take the grip, roll it so it's inside out on the end, put the tape on the lens and roll the grip back in place, it will work perfect, then just do the same thing on the other end of the grip
    Mike Leggero
    http://www.michaelleggero.com
